Adjusting the brake light switch? - Defender Source
Old April 20th, 2006, 12:16 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My brake lights only work spratically... they maybe work 25% of the time. Anyways, I think I found the switch, but how do you adjust it? I only see one adjustment, and it is a tiny, thin bolt. How do I make this thing more sensitive?
Old April 20th, 2006, 12:47 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
the switch is on the back of the servo. it is just a plastic threaded piece. to adjust tighten or loosen untill the sensitivity you require is obtained.
Kris
Old April 20th, 2006, 12:55 PM
oldscratchggf
nate
95 d90
Sorry, I am not the most mechanically inclined... but in lamens terms, is the servo the big black box directly to the left of the clutch master cylendar?
Old April 20th, 2006, 12:57 PM
Billakris's Avatar
Billakris
Kris
That would be it
Kris
Old April 20th, 2006, 01:00 PM
oldscratchggf
nate
95 d90
thank you, i appreciate it
brake, ht, switch
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
