Adjusting Tdi valves/tappets - Defender Source
Old December 21st, 2008, 09:47 AM
Did a search and didn't find anything. Has anyone else found a primer/ how to on doing this online ? Changing the oil every 5k and adjusting he tappets every 12k are said to the keys to long engine life.
Old December 21st, 2008, 10:15 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
There is a thread called "adjusting valve clearance 300 tdi" from last september.
Lot of infos.
Good luck.
- Charles Eames
Old December 21st, 2008, 10:47 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Doug....do you not have a shop manual for these things yet?
It's really easy to do (the rule of 9....when #1 valve is loose adjust valve #8...the total will always add up to 9) but the manual will describe it better than I ever will.
I like to do it when the motor is dead cold like before it has been run at all that day.
I also change the oil every 3k and adjust the valves every 3rd (9k) for motors with les than 60k total and every 12k for older motors as they seem to need less adjustment. Mine didn't need anything last time I checked. I use the shorter service intervals as my heap leads a fairly hard life.
Matt Browne
Old December 21st, 2008, 12:12 PM
Matt,
I haven't. Stupidly have the -89 book and haven't bought the 90 on yet. I have been cheating and getting what ever info I need from the net. I have only put about 2k on this engine so far but want to address everything early on. The engine is purported to have just around 110k. It looks very simple as compared to working on BMW M cars where one "shims" the valve clearance. So cold @ .20mm it tis.
Old December 21st, 2008, 02:23 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Doug
I can fax the pages from work tomorrow if that helps. My truck is in getting a ton of stuff done as I type this and the valves adjusted is one of those things. The other is stripping the front of the engine to the block and removing the oil pan to inspect the lower end.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old December 21st, 2008, 02:33 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by Maryland 110
Matt,
Would have liked to be more helpfull but my shop manuals (and the shop) are 5000 miles away right now
110k...must be getting ready for the 2nd cambelt eh?
Matt Browne
Old December 21st, 2008, 09:58 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Ok Matt I'll bite where are you thats 5000 miles from the shop?
Eric
Eric Riston
Old December 22nd, 2008, 08:35 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
When you do the valve adjustment that I should do since I have 10k on the motor now, do you need a new cover gasket?
Legend in My Own Mind.
Old December 22nd, 2008, 10:39 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
They are rubber so it should survive but they are cheap enough to have on hand.
Eric
Eric Riston
Old December 22nd, 2008, 05:19 PM
[QUOTE=junkyddog11
110k...must be getting ready for the 2nd cambelt eh?[/QUOTE]
Yup just replaced: starter, cam belt, water pump, radiator, and went full width with a new intercooler.
Gave Rooster Ron Peppard a ride around the Capital beltway in her last night a 75mph.
Glow plugs seem to be toast- she grudgingly started this morning in 16 degree weather.
Old December 22nd, 2008, 05:41 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Glad to hear it's catching on
Old December 22nd, 2008, 07:38 PM
Its cool-everyones doing it !
Old December 23rd, 2008, 10:10 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
75mph? Sounds like your tires are too small.
Old December 24th, 2008, 02:49 PM
LOL- thats highway cruise with 285.75.16's per the garmin. I have pushed up to the mid 80's but that gets sketchy with a couple hundred pounds on the roof rack.
Old January 8th, 2009, 03:19 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Eric
Hawaii. Big surf. Just got back. Had to shovel the slut out to leave.....and shovel it out to get home. Things might have been better if I'd put the glow plug relay back in........."grudgingly started"
'dja get those valves adjusted OK Doug?
Matt Browne
Old January 8th, 2009, 03:49 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Cool I'm sure you needed a vacation.
Eric
Eric Riston
tdi
adjusting valve clearance 300 tdi discotdi Defender Technical Discussions 13 September 19th, 2008 04:53 PM
