Adjusting rear axle alighnmnet, help - Defender Source
Old June 26th, 2015, 09:21 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Looking for suggestions and expertise
So Newman was following me back from HH and noticed the 90 was "dog-Legging" down the road with the rear of the truck tracking to the right of the front. When I got back to the house I wrapped a string around all four tires to check alignment and this is what I have found. Pic 1 shows the 1"space between string and tire, at the front of the rear left tire. The front tires looked good. I also looked at the rear wheels and how they were centered in the wheel opening, pic 2, the rear left tire sits about .5" to 3/4" further to the front compared to the opposite tire, and as confirmed by the string.
See crude pic for my illustration as to what is going on.
I will pull the stock trailing arms down and check bushings, but he frame side bushings are the orange poly and look good on both sides
Solution?
1. Adjustable trailing arms, nut in the budget.
2. Space out the shorter (left) trailing arm
3. Shorten, some how, the longer (right) arm
4. Do a little of both.
ID:	123690   Click image for larger version
~ Semper Fidelis ~
Old June 26th, 2015, 09:38 AM
rovertrader's Avatar
rovertrader
Dale
You are assuming it is the rear, but is the truck lifted? If so, the panhard pulls the front axle to one side. I suggest having an alignment shop get you accurate findings before doing anything.
Old June 26th, 2015, 09:42 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Sitting stock right now. but noticed rear spring seats are pretty crusty, probably doesn't help.
I am scared of most of the "alignment" shops around my location. If the machine doesn't tell them they make something up, but will ask around.
~ Semper Fidelis ~
Old June 26th, 2015, 09:47 AM
rovertrader
Dale
Our guys have the laser alignment, and it is pretty accurate. I just think you need an accurate base line before starting to change things. Also, if the front springs are sagging, the axle moves the opposite from lifting....
Old June 26th, 2015, 09:51 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Good point, does currently sit 1/4 lower in front. I have 2" lift springs and new shocks and spring seats, HD steering rods w/TREs ready to go in. Worth installing then sort this out with healthy components installed?
~ Semper Fidelis ~
Old June 26th, 2015, 09:58 AM
Another easy thing to check before spending money is:
1. Measure lengths of trailing arms.
2. Measure positions of rear trailing arm mounts on frame relative to front radius arm mounts.
All it takes is some tape measure.
speedpin's Avatar
speedpin
1985 130 Gen IV
And just to clarify the rear axle looks to the eye and measures miss aligned, as exaggerated in the crude drawing. Not saying the front is perfectly aligned but rear seems to me more of the culprit.
------ Follow up post added June 26th, 2015 10:00 AM ------
will take more measurements this afternoon. I did It quickly and noticed some variance but cant remember the details.
~ Semper Fidelis ~
Old June 26th, 2015, 10:20 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This. A few minutes with a tape measure will shed some light on it. Check the integrity of your bushings and make sure the trailing arms aren't bent.
Also, you drive a Land Rover and its entirely possible things are a little........off. The rear axle on my '98 D1 sat further to the drivers side than it did the passenger side.
You can space the trailing arms very easily with a few big washers from Home Depot.
Old June 26th, 2015, 10:32 AM
You could also have bend axles, so it is probably best t get an a check with a 4 wheel alignment machine to see where everything is before trying to correct things. A string test can be misleading.
Old June 26th, 2015, 10:36 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Any frame work like replacement rear 1/4 chassis?
Old June 26th, 2015, 10:44 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
No. New rear crossmember, but frame is solid and looks to be straight with no impacts/damage
~ Semper Fidelis ~
Old June 27th, 2015, 08:59 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Measured trailing arm mounts to frame. Like mentioned above. Truck must have been a friday build. 1/4 inch more forward on left side. Added 1/4 inch spacer and seems about perfect. Moving forward to replacing spring seats and lift springs..
~ Semper Fidelis ~
axle
Adjusting Defender Drum brakes landrovered Defender Technical Discussions 3 August 21st, 2012 08:30 AM
Adjusting Tdi valves/tappets Uncle Douglas Defender Technical Discussions 15 January 8th, 2009 03:49 PM
adjusting valve clearance 300 tdi discotdi Defender Technical Discussions 13 September 19th, 2008 04:53 PM
Adjusting wheel stops on orgin equip Happyxhour Defender Technical Discussions 2 December 3rd, 2007 10:45 PM
Adjusting the brake light switch? oldscratchggf Defender Technical Discussions 4 April 20th, 2006 01:00 PM
