Adjusting R380 linkage--hard to shift to 3rd - Defender Source
Old April 21st, 2010, 10:17 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I got my truck running tonight and went on a short test drive. I am having difficulty shifting from 2nd to 3rd with my new R380 transmission--I figure there is a way to adjust the linkage to make the transition smooth, I just can't find out how. I have to wiggle the gear lever around until it finds its 'slot'. Any advice?
Thanks!
Old April 21st, 2010, 10:22 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Does the stick have loose play in it when you are in neutral? There are those two 10mm or 8mm bolts that push the weird double sided spring up to tighten the slack in the stick... that could be it. But it sounds like you are having more of an internal shift issue. Is that it or are you talking about just a loose stick that won't stay straight when shifting through the gears?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old April 21st, 2010, 10:29 PM
maybe this?
http://www.ashcroft-transmissions.co...ory_5.html#a31
Thanks!
Old April 22nd, 2010, 07:59 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
IF its a new or rebuilt trans, there are adjustment screws to set the stick.. Follow Daves link. I can take a pic of a a trans if needed to show you what they mean.
Legend in My Own Mind.
Old April 22nd, 2010, 09:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks, guys--I am pretty sure it is the 3/4 adjusting springs. I will take a look at those and tweak it. Much appreciated.
------ Follow up post added April 22nd, 2010 03:29 PM ------
Yep, adjusted the 3/4 resting position and shifts great. Now just to fix that leaking fuel injector!
Old April 22nd, 2010, 11:57 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice....
Old April 22nd, 2010, 12:14 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
took me all of 10 minutes to adjust--8 of those minutes were removing the boots and such. I love the easy ones! If any of you have difficulty in shifting into 3/4 gears (not synchro issues, but as if the shifter is not going into the right slot), then this is a quick adjustment that makes a huge difference.
Just follow Dave Ashcrofts description from the link given by Ren above...
r380
Shift knob for R380 61rover For Sale - Parts 2 September 19th, 2009 11:08 PM
R380 Transmission Shift Lever Needed e90miller Wanted 1 August 17th, 2009 11:30 AM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
D-90 3rd seat up front ?Possible - How? paulb Defender Technical Discussions 17 October 28th, 2004 07:26 PM
difficult to shift my 94... JRowe Defender Technical Discussions 8 January 26th, 2004 01:21 PM
