Adjusting headlights on RHD Vehicle - Defender Source
Old March 14th, 2016, 04:44 PM
Yorkie
Mark Whitehouse
1989 D90
All
Apologies for what must be a really simple question. I am purchasing a RHD Defender 90, it is a recent import and hasn't had any adjustments made to the headlights for LHD roads. How do I make the adjustment or do I need to buy new units?
TIA
Old March 14th, 2016, 05:09 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
If it has its RHD/left hand traffic home market headlights, then you will need to replace them with LHD/right hand traffic units. On low beam, the headlight pattern shines up and away from opposing traffic to illuminate signs, etc. on the side of the road. Using the wrong headlights will cause glare for opposing traffic.
Hella, Cibie, someone in the UK licensing the Lucas brand, and the Far East all make LHD H4 units, w/ Hella and Cibie being the best of the group.
...and congrats on the new truck. Post pics.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old March 14th, 2016, 05:13 PM
Yorkie
Mark Whitehouse
1989 D90
So there is no way of adjusting the current units?
Old March 14th, 2016, 05:19 PM
61rover's Avatar
61rover
John Crouse
The buckets adjust. But you do need US spec bulbs.
pitchrollyaw
wayne p
1985 d90 2.5NA
No. Not as a proper solution.
I suppose you could try and get your hands on those triangular stickers used in Europe for blocking the upwards portion of the beam, be a cool novelty for a little while, but you really need the proper lights.
Car Headlamp Converters | Headlamp converters | Essentials for driving in EU
------ Follow up post added March 14th, 2016 03:25 PM ------
Here is a decent explanation. Refer to the beam pattern diagrams on the bottom of the page.
Halfords Headlamp Converters - Fitting Information
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old March 14th, 2016, 05:30 PM
61rover's Avatar
61rover
John Crouse
Headlights are relatively cheap. Old school bulbs are $17/each at Autozone. The H4 conversions are $25 - $50/each depending on brand. Once in, the headlamp buckets have two adjusting screws; one for up down, one for right left. When I adjusted mine, I parked about 20 feet from a big wall at night and adjusted appropriately.
Old March 14th, 2016, 05:33 PM
New complete sealed halogen beam lights are between $10 and $20 each. I actually find the cheapest halogens to last the longest and work reasonably well.
Old March 14th, 2016, 05:37 PM
Yorkie
Mark Whitehouse
1989 D90
so this is 1989 vehicle anyone know what lights will fit, did the headlight connector change at all from 1989 to later years? I'd like to convert to LED but after paying for the vehicle may have to stick with halogen.
Old March 14th, 2016, 06:11 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
These will fit and should be plug and play:
http://www.amazon.com/GE-6014-Sealed...6014+headlight
These are slightly better:
http://www.amazon.com/SYLVANIA-Silve...6014+headlight
These will make better use of the wattage by keeping the illumination on th eroad more than the trees:
Hella 7" Round 9003 Vision Plus DOT Conversion Headlamp, HL70477 | Rally Lights
All should be plug and play. The wiring to the lamps via a molded 3 wire connector is blue with white trace, blue with red tracer, and black is ground (or Earth), and in a perfect world, they are in the correct slots!
Is there a black trim panel surrounding the headlamp and indicator lamps? Post a pic, and I'll bet we can talk you through it...
Email is
Same place, new dogs.
Old March 14th, 2016, 07:18 PM
Remove your RHD headlights and replace with LHD version.
The Hella lights listed above are fantastic.
Old March 14th, 2016, 07:34 PM
Yorkie
Mark Whitehouse
1989 D90
Thanks all I go will go with the Hella.
The car also has some rally spot lights on it will these be OK?
Old March 14th, 2016, 07:55 PM
Roverlab
Trevor Griffiths
Driving lights are typically single filament and aimed straight ahead, so no issues unless aimed really, really badly!
Email is
Old March 14th, 2016, 08:06 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Good choice on the Hellas. Look for the 'e-code' ones as opposed to the Vision+. The V+ are a quasi sealed light with a US DoT light pattern, a replaceable bulb and, while better than a sealed beam, don't seem to have as crisp a cutoff as the actual Euro spec ones.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old March 14th, 2016, 08:24 PM
Yorkie
Mark Whitehouse
1989 D90
Is this the correct one?
Amazon.com: Hella 7" Round E code Headlamp Kit with 100/80w Bulbs - PAIR: Automotive
Old March 14th, 2016, 08:45 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I think you need the 60/55 watt to be road legal
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 14th, 2016, 08:46 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Originally Posted by Yorkie View Post
Yes, those are the good lamps but I would stick with stock wattage bulbs, 55/60 watts. Hi watt bulbs should be used with upgraded wires and relays and are probably overkill.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old March 14th, 2016, 09:01 PM
Yorkie
Mark Whitehouse
1989 D90
Brilliant thanks All!!
Old March 14th, 2016, 09:15 PM
Since I custom made my harness, I went hi wattage. Over kill, yes. Unless you want to avoid adding additional driving lights.
Old March 15th, 2016, 05:37 AM
Roverlab
Trevor Griffiths
Agreed, I use E-code on all of my own Rovers and customer's Rovers. And with Hella waterproof relays to take the load off of the somewhat frail stock headlight switch. Rally lights offers a 55/80watt H4 bulb that fits the E-code lamp. I was trying to make for an easy solution to his concern. I'm assuming a diesel engine so there is no real concern about driving faster then one can see......
Email is
Old March 15th, 2016, 06:48 AM
Yorkie
Mark Whitehouse
1989 D90
Hi Trevor its actually the 3.5 V8. What is involved installing the waterproof relays, is it a simple DIY job? Also sent you a PM.
ht, lights, rhd
Adjusting Defender Drum brakes landrovered Defender Technical Discussions 3 August 21st, 2012 08:30 AM
Adjusting Tdi valves/tappets Uncle Douglas Defender Technical Discussions 15 January 8th, 2009 03:49 PM
adjusting valve clearance 300 tdi discotdi Defender Technical Discussions 13 September 19th, 2008 04:53 PM
Adjusting wheel stops on orgin equip Happyxhour Defender Technical Discussions 2 December 3rd, 2007 10:45 PM
Adjusting the brake light switch? oldscratchggf Defender Technical Discussions 4 April 20th, 2006 01:00 PM
