Adjusting Backlash on RRC end drive... - Defender Source
Old August 6th, 2015, 02:39 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Any tips on how to adjust backlash? I just replaced the swivel grease, can i remove the entire ball housing assembly in order to remove the axels? what is acceptable pinion to ring gerar play?
Thank you;
-Gabe.
Old August 6th, 2015, 02:48 PM
Yes.
4 to 7 thou is the R&P backlash setting.
Might be best to download a workshop manual.
Old August 7th, 2015, 11:04 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I have a manual, but im wondering what could cause the backlash to be off so much. the is like 1" of play at the pinion before the wheels are engaged.
Old August 7th, 2015, 11:18 AM
Play at the pinion flange is not just backlash in the pinion/ring gear. It is a combination of backlash from all of the components. 1" sound normal.
Old August 7th, 2015, 11:50 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I was looking at videos where it looks pretty tight, and i feel a vibration around 35 MPH and goes away until i reach 65MPH then it vibrates if i let off the gas. It gets worse as i feather the gas...
Mine has way more play than this (end of the video)
https://www.youtube.com/watch?t=318&v=B7jG-9d_TSM
Old August 7th, 2015, 12:03 PM
Most likely a u-joint.
That video is just showing pinion/ring gear backlash. In the truck you see the combination of pinion, diff spider gears, 4 splined joints and the two CVs. It adds up and 1" at the outside the pinion is within a range of normallity.
Old August 7th, 2015, 12:09 PM
there is no play spec per se between the pinion flange and ring gear. there is a backlash spec but what that translates to at the pinion flange is unknown.
there is a preload spec on the bearings.
ac
Salisbury Backlash How much is Normal? Wilboro Defender Technical Discussions 5 April 13th, 2015 10:08 PM
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Rear diff backlash? TND90 Defender Technical Discussions 2 February 7th, 2010 02:50 AM
Steering Wheel backlash adjustment Mike Finn Defender Technical Discussions 0 December 20th, 2005 12:07 PM
Rockware trailing links, backlash artm Defender Technical Discussions 1 June 14th, 2005 03:59 PM
