Adjustable panhard install? - Defender Source
Old June 20th, 2014, 10:57 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Whats the best way to install and adjust a RTE panhard arm?
Old June 20th, 2014, 11:16 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Install is a breeze, although it's usually easier with two people.
Mount the axle side first, and have someone slightly turn and hold the steering wheel to get the panhard bracket on the chassis to line up with the end of the rod, and slide your bolt through.
As for adjustment, it's going to require a couple of measurements. The panhard effectively shortens the linear distance between the frame and axle mounts as the axle is pushed away from the chassis (as seen with lift kits), and the axle becomes off-centered and is pulled towards the driver's side of the truck. Depending on the amount of lift you're running, this distance will change.
Pull measurements at ride height with the stock panhard installed, find the difference, if any, between the driver's and passenger's sides, and lengthen the RTE rod accordingly.
-Ash
Geared Restoration Co.
352-572-3236
Old June 20th, 2014, 12:25 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Install is easy. I had a harder time keeping the heim from developing slop, over and over again. I really think RTE should have kept the stock bushing at each end like the TF one does. In the end I went with a threaded poly bushing end at the frame side, which required me reaming the mount hole to 5/8" but that poly end has outlasted the three previous Heims.
QT Adjustable Panhard Rod crown14 For Sale - Parts 2 February 5th, 2010 10:04 PM
Adjustable Panhard Rod crown14 For Sale - Parts 7 February 3rd, 2010 09:40 AM
Adjustable panhard D90user Defender Technical Discussions 3 October 9th, 2006 01:17 PM
RoverTym Adjustable Panhard Rod cbass For Sale - Parts 3 August 16th, 2005 12:41 AM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
