Adhesive Removal - Defender Source
Old October 19th, 2004, 02:24 AM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Adhesive Removal
Looking for a recommendation on an adhesive remover. The previous owner put duct tape along parts of the top rear tub rail. What's the best I can use that won't damage the paint underneath? Although, I might have to paint anyway after I find what he was hiding with the tape.
Paul
Old October 19th, 2004, 10:49 AM
jabber
m j
110
You can use mineral spirits and lightly rub the adhesive off. I've used it for removing the "range rover" letters on the front and back of my RRC. After getting the adhesive off, wash the area then use a rubbing compound.
You can pick up mineral spirits at any hardware store, auto store, or home improvement.
Old October 19th, 2004, 11:18 AM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
This stuff is great. 3M adhesive remover
Insert pithy quote here.
Old October 19th, 2004, 11:22 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
The 3M stuff is really good, also some stuff called Goo Gone works very well too.
Old October 19th, 2004, 01:26 PM
c2sox's Avatar
c2sox
Al Cruz
93 110 #428 and 01 Disco SD7
I've used acetone to remove adhesive from various things in the past.
Al
Old October 19th, 2004, 02:25 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Al
Whoooo-who! Acetone and paint don't mix! I take it you didn't use this on your D110 Al!
Anyway, I'm not sure I understand the location of the "top tub rear rail," but if this is a painted surface then try isopropyl alcohol (nail polish remover). That should do the trick and won't effect your paint.
DJ
Old October 19th, 2004, 03:02 PM
proulx70's Avatar
proulx70
Paul S.
Thanks guys!
Best regards,
Paul
Old October 19th, 2004, 04:44 PM
c2sox's Avatar
c2sox
Al Cruz
Hehe...come to think of it I've never had to remove adhesive from a body panel yet.
Al
Old October 19th, 2004, 07:47 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
lighter fluid is good too
Old October 20th, 2004, 12:42 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Lightbulb Tarminator - By Stoner
If you guys have not used this stuff . . . you should.
I could not do without it. They have allot of great products including
More Shine Less Time - non soap based tire shine that works without making it look like a "pimp ride"
Invisible Glass.
Been using their products for 8 years.
http://www.moreshine.com
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
