Adding leds for engine infos - Defender Source
Old April 30th, 2010, 03:56 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm adding a couple of leds to get a little extra
infos on engine and cooling, which is not a luxury
in this very hot weather.
I have a blue led that goes on when the a/c
compressor clutch trigger and a green one when
the a/c condenser fan goes on.
Both are quite easy to wire, using the relays
of both system.
I want to add a red or amber one and have
it working with the a/c thermoswitch.
The thing is that particular thermoswitch will
cut the flow of current after passing i think
106 C. So i need to light a bulb when current
is off ...
I was told about a PNP diode or something like
that.
Anyone familiar with electronics ?
- Charles Eames
engine
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Adding a fuel pressure gauge? Hans Defender Technical Discussions 5 December 7th, 2008 03:21 PM
When adding a Lift..... ttrover Defender Technical Discussions 10 November 11th, 2007 08:09 PM
adding air conditioning to a soft top cdb Defender Technical Discussions 13 June 9th, 2007 04:58 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
