Adding Intercooler to a 19J Turbo - Defender Source
Old March 18th, 2016, 10:32 PM
Raquen
Matthew
none
Has anyone added a water to air intercooler to a 19J?
I read that allard Intercoolers use to sell a kit with really good results. From what I read it made the 19J comparable to the 200TDI.
I have a 1988 D110 with a 19J Diesel Turbo.
I am looking into installing a water to air system and adjusting the boost on the turbo and balancing it with an adjustment to the fuel pump.
Has anyone done anything like this?
Thanks!
Old March 19th, 2016, 08:50 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Why not use a air to air? Just use a 200tdi intercooler. The intake manifold can be machined to have a hole on the front (just like a 200tdi). Done that on my 19J . Don't expect much hp outta 19J even in intercooled mode. Just saves the engine life a bit as the 3-4 cylinder tends to get hot.
Old March 19th, 2016, 12:56 PM
bish1865
Bruce Bishop
1985 Defender 110
I put one on my 19J. It was an after market with 2" plumbing. I had to do a modification to my slam panel supports to allow it to be mounted in front of the radiator. Having installed it when the engine was rebuilt I have nothing to compare performance too. I have no problem running freeway speeds but I never push it too hard. My egt gauge reads at it highest between 900 and 1000 degrees. But as soon as fifth gear and cruising speed is reached it drops between 650 an 700. The engine temp never runs above 175 even on a 100 degree day. I did put a cut down Rangy fan in it throws a lot of air across the engine. I think the 200 tdi would be the way to go if your not into fabrication.
Old March 21st, 2016, 10:36 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I may be able to put together an intercooler kit for you
Legend in My Own Mind.
Old March 21st, 2016, 10:41 AM
Why water to air?
Are you drag racing your truck?
Old March 21st, 2016, 11:12 AM
Raquen
Matthew
none
Did either of you increase the turbo pressure and dial up the fuel pump? We haven't put the turbo on a gauge, we're guessing stock is only 4-6 lbs with an intercooler you can increase the pressure to 18lbs. I am probably looking at 12-14 to be safe.
As for air to water. The first is no space for the air hoses on my model and it would be serious spaghetti mess. Second and the main reason I can get below ambient air temp and greater air density. Plus less hoses, less loss and way easier mounting options.
And no drag, just need extra hp to get up the sierras and it seems an easier and cheaper option the know sourcing as 200TDi
Old March 21st, 2016, 11:24 AM
I dont think you really understand how turbos and intercoolers work
Even if you have a theoretically perfect intercooler, your turbo will have an extremely short life at 1.2 bar. My recommendation is to replace the turbo with a unit with a larger compressor, like a GT28RS, GT2056, GT2560, etc. You need something that can push 19lb/min at the middle of the efficiency island. You'd be going from 40% or less efficiency and ~180,000 rpm to 73% efficiency and ~130,000 rpm. you could probably forego running a complex intercooler and replace it with a smaller one.
Some folks on here have been fueling up and boosting their engines. They could probably provide more insight into their experiences.
Old March 21st, 2016, 01:41 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
On my 19J I am running a large Allsport full size intercooler...the stock wastegate opens at about 9lbs...you don't want to go too much higher due to this engine not being the strongest design...the biggest improvement was replacing the boost diaphragm which prob has a small hole that then ended up having a big tare...with that replaced the engine became much stronger...you could run a manual boost valve to get it up to about 13lbs, but I didn't see too much of a difference and didn't want to kill the motor...My EGT also runs around 650F around town and at highways speeds about 950F at the highest...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 21st, 2016, 03:09 PM
Raquen
Matthew
none
Hey cool thanks for the info, we weren't sure about the compressor and if it needed to be upgraded but we suspected it would. I know the TDi swap is a common one but I'm just trying to see if I can get something comparable with out the big conversion.
Old March 21st, 2016, 03:45 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
As far as I know, the power from the 200tdi comes from the injection system, the boost and fuel can help but the lower ends up being limited by the engine design. Also bigger turbos spool up at higher rpm which means less low end power..
Old April 16th, 2016, 12:44 PM
Raquen
Matthew
none
Are you talking about the boost diaphragm in the injector pump or the diaphragm in the waste gate actuator?
Old April 16th, 2016, 01:14 PM
No, most of the power is from the boost. 15 psi nearly doubles the amount of air entering the engine. As long as you provide enough fuel for the air, the power follows.
Old April 16th, 2016, 04:57 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The boost diaphragm inside the injector pump...they tear and you loose much of the power plus it will allow fuel to reach the turbo...
Old April 18th, 2016, 02:50 PM
Raquen
Matthew
none
I chatted with a parts house and they were telling me the stock injector pump for a 1988 110 with a 19j doesn't have a boost diaphragm and they thought it was only applicable if someone updated with new 3rd part pump.
Is this the case? Were people referring to TDi's or did this guy just not know what he's talking about.
Old April 18th, 2016, 03:01 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
7243-006 which may be superseded by 7182-643, but check
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 18th, 2016, 03:03 PM
It is on the pump next to the block.
Replacing 2.5TD boost Diaphram - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
Old April 18th, 2016, 03:36 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Mine was even worse looking then the one in the write up..
Old April 18th, 2016, 03:44 PM
The Dro
Dro
1988 Ninety
read my previous post...
http://www.defendersource.com/forum/...tml#post731788
19J hard cold start (Fuel in Turbo Vac line) icnsltmfg Defender Technical Discussions 6 October 27th, 2015 10:26 PM
Dead Turbo on a 19J 2.5TD icnsltmfg Defender Technical Discussions 9 October 4th, 2015 04:19 PM
White 1988 Left hand drive Turbo Diesel/19j 5 door Uncle Douglas For Sale - Vehicles 41 July 27th, 2015 06:40 PM
2.5TD 19J Turbo Boost Pressure Numbers? richord Defender Technical Discussions 1 August 25th, 2014 02:19 PM
Diesel turbo 19J engine parts CDNRover For Sale - Parts 6 August 7th, 2009 11:08 AM
