Adding ABS to NAS Defender - Defender Source
Old October 12th, 2009, 11:08 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Is it possible or has it this been done?
Can you add ABS to a NAS spec. Defender???
I am tired of the old pump-N-pray when the streets are slick and I need to stop.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old October 12th, 2009, 11:11 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
All things are possible, you need ABS exciters on the CVs/rear axle, the ABS ECU, the ABS master cylinder and wheel sensors for all four wheels. Then you need a lots of patience.
Old October 12th, 2009, 11:13 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I have a friend with a Disco1 who is looking to get rid of his ABS... maybe you two could swap the parts?
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 12th, 2009, 11:18 AM
Get better tires... ABS is not needed and can make things worse, IME.
Old October 12th, 2009, 01:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Could it even be done with the drum brakes in 110?
Old October 12th, 2009, 01:25 PM
You would need abs sensors which would mean replacing both the salisbury and the front axle with something ABS compatible.
Old October 12th, 2009, 01:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
What ABS parts did the 97s come with?
Old October 12th, 2009, 01:31 PM
discotdi
Todd Miller
Land Rover
No ABS parts on any NAS Defenders. 1997 disco's have abs.
Old October 12th, 2009, 01:32 PM
1997 D90s have the wheel sensors. You could probably add it to a 1997 D90 with a lot of work as opposed to the metric ton of work needed to fit it to a 1993-95.
Old October 12th, 2009, 01:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why did the 97s have the wheel sensors?
Old October 12th, 2009, 02:06 PM
Because rover is retarded.
Old October 12th, 2009, 02:08 PM
They are rough road sensors...
Rover probably did it because they had a ton of axles and CV from the discos.
Old October 12th, 2009, 02:19 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I thing because ODBII was required to be implemented in all cars sold in North America in 1996 that Rover could or had to put ABS sensors and other sensors on the 97 Defenders.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old October 12th, 2009, 02:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
so what do they do?
Old October 12th, 2009, 02:48 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Hi Jon,
Try to apply the brakes with better technique, i.e. smoother. I won't get into a whole threshold brake talk here, but the initial push of the brake pedal must be smooth enough to transfer some weight to the front tires, then you can push harder because that weight transfer pushes the tires into the road surface more. If the front tires do lock up, don't pump the brakes (like my driver's ed teacher told us to do) and completely release the brakes and then jam them back on again over and over. All you need is a smooth release of a LITTLE brake pressure...just enough to get the tires rolling again, but not too much to transfer the weight off the tires. Little tiny adjustments to keep the tires rolling.
Easy to say, but tough to do sometimes in an emergency situation. That's all ABS does though. It detects lock up and releases a touch of pressure at about 17 times a second. Even if you have ABS, you should know how to do this.
Also, (and I'm really not trying to be preachy, this is just what I do) you should not be engaging your ABS that often where you should be "tired" of it. If you know the streets are slick, back off the car in front and anticipate more. Red90 is right too, better tires will definitely help. Tires are the most important piece of equipment on your rig, because they're the ONLY thing that's touching the road.
Hope that helps!
Pete
Old October 12th, 2009, 03:12 PM
x2 to what Pete said with the additional comment that MT tires are terrible in rain. Get something with a lot of sipes and you will be able to stop fine.
Old October 12th, 2009, 03:16 PM
discotdi
Todd Miller
Land Rover
i think the 97 models have a speed transducer that relays the speed to the speedometer perhaps it gathers some info from the wheel speed sensors. but nothing to do with the brakes.
just buy a 1999 or above with ABS from the UK and swap the vin #, easy.
Old October 12th, 2009, 03:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
How can I put airbags in my 90?
Old October 12th, 2009, 04:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
I hope you know I was joking
Old October 12th, 2009, 04:29 PM
I want to add crumple zones.
I'm sure you could buy all the components for ABS starting with the axles, the ABS pump and sub systems, and the computer etc (perhaps as used or take-out), but I think it would definitely be more cost than its worth. I've only activated ABS once on a car and that was during a panic event at about 170kms/hr on the autobahn.
nas
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
1995 NAS Defender 90 Workshop Manual MDS Defender Technical Discussions 3 November 21st, 2006 05:58 PM
1995 NAS Defender For Sale $15,950 ron For Sale - Vehicles 28 June 27th, 2006 09:34 AM
NAS Defender 110 lrnasd90 For Sale - Vehicles 9 October 29th, 2005 02:01 PM
