Adding a fuel pressure gauge? - Defender Source
Old May 10th, 2008, 09:51 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Just a though here, trying to add an underhood fuel pressure gauge, anybody ever done this before?
First though is to add an adapter between the inlet line and the fuel rail, but I'm terrible with metric threading, so what threads is that there?
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 11th, 2008, 07:03 PM
Hans's Avatar
Hans
Hans Haase
Finally some luck!
http://www.aeincorporated.com/Star/?...9kaXNwbGF5PTEw
The parts manual lists this as fitting the 14CUX style fuel injected 3.9's and 4.2's.
Not sure if this goes at the filter threading or the fuel rail, but it gives me the threading that I need to work with M14 ball-seat.
-Hans
My oil line fix
Old May 14th, 2008, 04:28 PM
Hans's Avatar
Hans
Hans Haase
scratch that, the M14 fittings didn't fit anywhere I could find. Too small for the fuel filter theadings, too big for the fuel rail.
My oil line fix
Old May 15th, 2008, 10:47 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I have spy pics of how I do it. What do you have to offer me?
legend in my own mind
Old May 15th, 2008, 03:37 PM
Hans's Avatar
Hans
Hans Haase
I'll trade you my $9 adapter method to put a 2nd speedometer sensor into a pre-'95 truck, so you can put in an electronic speedo?
My oil line fix
Old December 7th, 2008, 03:21 PM
Hans's Avatar
Hans
Hans Haase
Bumping this one back from the dead, still hoping to mount one up at some point.
My oil line fix
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
How to check fuel pressure? Heath Defender Technical Discussions 3 January 11th, 2005 02:28 PM
Help wth Fuel Gauge (that works sometimes) ToyCrusher Defender Technical Discussions 14 October 20th, 2004 08:43 PM
