Adding a 2nd alternator pulley - Defender Source
Old September 9th, 2009, 07:44 PM
Jackd
Jack DiPiazza
1983 110
I have an 83 110 with a 3.5l V8. I am putting a larger alternator in the truck and the shop is recommended a second pulley. Does anyone know where I can get an "add a pulley" or a replacment pulley designed for 3 belts?
Old September 9th, 2009, 08:41 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
do you mean a second belt?
Old September 10th, 2009, 12:44 PM
Jackd
Jack DiPiazza
1983 110
yes i need to add second belt
Old September 10th, 2009, 02:53 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For the alternator, you should be able to get a triple groove pulley from the alternator mfg.
You'll also need a 3 groove pulley for the crankshaft, if it doesn't already have one.
Make sure the groove angles match between the alternator and crankshaft.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 10th, 2009, 07:13 PM
Jackd
Jack DiPiazza
1983 110
The problem is I can't find a 3 groove pulley for the crankshaft.
Old September 11th, 2009, 10:13 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Well, you could always get one of the correct diameter and pitch and weld it on.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
alternator, pulley
2nd row seats for 110 Overlander Wanted 5 November 21st, 2017 04:29 PM
When adding a Lift..... ttrover Defender Technical Discussions 10 November 11th, 2007 08:09 PM
adding air conditioning to a soft top cdb Defender Technical Discussions 13 June 9th, 2007 04:58 PM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
