Actual lift measurement with OME - Defender Source
Old January 31st, 2006, 04:35 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Could someone measure their springs on level ground to tell me the compressed length of the OME 764 rear 761 front combination? How much actual lift did you get? If someone could measure a stock defender that would be great too.
I am trying to figure out new springs on a SeriesIII coil chassis which is supposedly the equivalent in terms of suspension to a D90. Only thing is its a lot lighter, 3000 lbs. I figure even with a winch(but no bull bar) I should stay with the MD front since the 2.25 is a lot lighter than the v8. Rovertyms are probably too much lift.
Old February 2nd, 2006, 04:18 PM
scoloco's Avatar
scoloco
'94 D90 ST
Kevin, No clue if this will help, but here are some measurements I took of the truck before and after applying OME HD/MD springs.
http://www.geocities.com/sucott/rover/basics.htm (at the very bottom)
ac
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
OME HD rears or similar 2in rear lift springs evilfij Wanted 1 December 15th, 2004 04:04 AM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
OME Lift Springs? Buckon37s Defender Technical Discussions 18 April 7th, 2004 12:01 PM
