Accessing Brake Pedal Switch - Defender Source
Old August 18th, 2013, 09:23 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Need to access for test, and probably replace, the brake pedal switch. It looks like it will be a real pain to get to it. Before I dig in, would appreciate input on the best way to access this part? Thanks. Mark
Old August 20th, 2013, 08:45 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Actually not too bad, at least on mine. It's part of the brake box, which I recently had to pull to replace the brake booster. Remove the brake master cylinder from the brake booster, but you can leave the brake lines connected. About five bolts or so holding in the brake box to the firewall. Should pretty much come straight out.
Old August 21st, 2013, 01:57 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Thanks for the reponse. I looked at my parts manual to find the number for the replacement. From that drawing I concluded (incorrectly) that the switch was on the cabin side of the bulkhead, in the innards of the dash. I was able to unscrew and verify the switch is faulty, without messing with the brake booster, etc. Much easier to get to on top of the booster box, under the hood, than I had initially thought.
ac, brake, switch
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
parking brake switch Campbell Defender Technical Discussions 6 September 20th, 2005 08:45 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
