Accelerator pedal sticking / not returning - Defender Source
Old September 5th, 2016, 03:13 PM
burlsube
Nick
1985 110 CSW
It seems like my accelerator pedal isn't springing back up once I take my foot off if it which is a little dangerous. It eventually will go back to the resting position or I need to pull it up with my foot. Is this just a simple swap out of the return spring?
Old September 5th, 2016, 03:51 PM
Most likely the cable as the spring is at the engine. What engine are we talking about?
Cables are cheap and easy to swap.
Old September 5th, 2016, 03:59 PM
Sounds familiar. This happened to me once for the first time approaching an exit on an interstate....
Removing the cable and lubricating will only delay inevitable replacement.
Don't delay!
Old September 5th, 2016, 04:07 PM
burlsube
Nick
1985 110 CSW
Originally Posted by Red90 View Post
Most likely the cable as the spring is at the engine. What engine are we talking about? Cables are cheap and easy to swap.
It is a 200tdi. Any chance it is the return spring by the actual pedal?
Old September 5th, 2016, 04:26 PM
burlsube
Nick
1985 110 CSW
Is there any way to sneak the spring off without taking the whole assembly off?
Old September 5th, 2016, 04:39 PM
Most likely the cable. The injector pump spring is very strong. The pedal spring does not do much other than to ensure some free play.
If it is left hand drive be careful with the routing as it is easy to get too close to the exhaust.
Old September 5th, 2016, 06:16 PM
burlsube
Nick
1985 110 CSW
Thanks. I'll give replacing the cable a try.
Pedal Pads, pedal pads, pedal pads wcampbel@nas.edu Defender Technical Discussions 15 July 10th, 2016 09:30 PM
'88 D90 swaying at "high" speed and gas pedal sticking ITALY2AMERICA Defender Technical Discussions 6 March 8th, 2016 07:39 AM
"Defender Returning to America" Spec Ad navydevildoc Misc. Chit-Chat 4 December 12th, 2014 05:32 PM
Returning a tranny for repair under warranty peachyracer Defender Technical Discussions 7 July 10th, 2012 10:41 AM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 09:23 AM
