Acceleration Thump - Defender Source
Old December 21st, 2011, 01:57 PM
Keebler's Avatar
Keebler
Kenneth Elliott
1994 D90 AA yellow (NAS)
Acceleration Thump
Hello to all.
I recently acquired my first D90.
I have a Thump that occurs during acceleration. Especially in 1st and 2nd gear in traffic. I can feel it in the floorboard.
I have looked at all the U joints, haven't had a chance to check out motor and tranny mounts as of yet.
does anyone have an idea as to what may be causing this?
Old December 21st, 2011, 02:05 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Check out the A-arm ball joint. If the boot is damaged it should be swapped out.
Other things include any of the bushings (radius arms) etc.
B/c you're new to your 90 here's the picture
Name:	Screen shot 2011-12-21 at 1.03.56 PM.png
Old December 21st, 2011, 02:46 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
^^^^ What he said;
A frame ball joint,
or Trailling arm joints eitehr end (although these usually give a "crab" steering effect with gas on/off)
Any of the front arm bushings
But my money is on the A frame one.
Old December 21st, 2011, 07:38 PM
Keebler's Avatar
Keebler
Kenneth Elliott
Damn, sure enough.
A-frame.
Thank you.
Most of the bushings aren't looking too hot, and my shocks are all leaking.
Does anyone know if there is a polyurethane bushing kit i can up date to?
Suspension options? I keep reading about safari guard, but seen no where to buy.
Old December 21st, 2011, 08:55 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You have a bunch of options in poly bush sets. Check all the vendors here on the boards or Ebay UK
Land Rover 110
Old December 21st, 2011, 11:52 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Those were likely the original bushings, so despite the rubber's bad rep, they are pretty durable, and I think the ride's better FWIW
ac
Intermittent Acceleration Failure ONLY from Stop -- 97 D90 pcscharfe Defender Technical Discussions 24 September 23rd, 2011 09:58 AM
Shaking on Acceleration 2.25 diesel Jpayne Defender Technical Discussions 34 September 16th, 2010 03:19 AM
300tdi weak acceleration on hills discotdi Defender Technical Discussions 4 July 7th, 2009 09:12 AM
Hesitation under acceleration durangorover Defender Technical Discussions 16 June 24th, 2009 07:17 PM
Stumbling during acceleration and load Bozman Defender Technical Discussions 8 June 14th, 2006 08:02 AM
