Accel/decel driveline vibration... - Defender Source
Old September 22nd, 2014, 09:53 PM
doktorno
Chris deZ.
1995 Defender SW
Hello, new to the forum. Threw a bid in on a '95 NAS SW that was up on ebay a few weeks ago and much to my surprise won the auction. Have not owned a Rover since 1996 when my '89 RR was totaled in an accident.
Now that D90 is in my garage I have been sorting through a few minor issues (like a missing condenser fan) and some driveline noise issues. Vehicle is stock with the exception of a 2" OME lift springs and shocks. Seems like more than 2" as the thing will not fit in my garage, but I have the part numbers off the Rovers North receipt.
Under acceleration and deceleration I get a vibration with a frequency that leads me to believe it is a driveshaft problem.
I thought that the driveshafts were suspect so I removed them and had them serviced by a reputable driveshaft shop here in Houston. They found them in good shape, just balanced the driveshafts and found the rest ok. Put them back on and vibrating just as before.
I also get a brief crunching sound that might be slack in the drivetrain...
Also have some mild hesitation at particular throttle settings.
Any suggestions would be appreciated.
Old September 22nd, 2014, 09:58 PM
Mild hesitation may be a worn throttle position sensor if ( and only if ) it occurs at exactly the same point every time.
Old September 22nd, 2014, 10:08 PM
Let's see some Alpine white pics!
Old September 22nd, 2014, 10:20 PM
doktorno
Chris deZ.
1995 Defender SW
Same place every time. Will see if there is a way to test the TPS in the manual. Or clean it?
Old September 22nd, 2014, 10:23 PM
Pinion angle, rear links should help solve your little problem . Which number is yours? glad you're back in a rover
doktorno
Chris deZ.
1995 Defender SW
Rijosho, only one lousy iphone picture now but the ebay ad is still up.
http://www.ebay.com/itm/1995-DEFENDE...p2047675.l2557
Old September 22nd, 2014, 10:50 PM
doktorno
Chris deZ.
1995 Defender SW
Thought the same, changed the bushings in the bottom link at the rear axle and the ones at the frame RNS033. #144.
Glad to be back. Already thinking of selling some of my German crap. Funny after over a decade without a Rover I still had the phone number to Rover's North memorized.
What about that center ball joint at the axle? Think it was part of the leveling device on my Classic?
Old September 22nd, 2014, 10:53 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
We need lots of pictures of your truck or it cannot be properly diagnosed.
Old September 23rd, 2014, 03:36 AM
So they said the UJ's were ok? Interesting.
My next step would be to remove the driveshafts one at a time and see if the vibes are still present.
Old September 23rd, 2014, 07:05 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Also might check your transfer case mounts. I cased a vibe for about two years and finally found it in my tcase mount. Deceleration growl could be a problem with the rear trailing arm length or a rear pinion bearing on its way out. Welcome back to the community.
Clay
Old September 23rd, 2014, 07:24 AM
Clay
You need adjustable rear links, try Rockware Rovertym etc
Old September 23rd, 2014, 10:45 PM
doktorno
Chris deZ.
1995 Defender SW
Checked motor mounts with the pry bar and they were groovy. Will get more pictures manana. Thinking about strapping the action video cam to the underside and taking a drive.
Truthfully, with the twitchy steering that I assume was caused by the lift screwing up the amount of caster, I considered going back to stock springs.
Old September 24th, 2014, 07:30 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would also look to the front drive shaft and replace it with a double cardan shaft. Even with a 2" lift some of the Defenders have suffered from a noise/vibration with the stock shaft.
Old September 24th, 2014, 10:59 PM
doktorno
Chris deZ.
1995 Defender SW
Took a few photos.
Tried to post them individually but no luck, so here is the link to a album.
https://www.flickr.com/photos/124610...7647988741401/
Also adjusted the door hinges on the driver's door, as the door was hitting the striker a bit low and one had to slam the crap out of the door. Need to order a few replacement pins for the door card.
Friend has a Napa store and there are no throttle position sensors in their system, or available as a special order. Bummer, could have had it at cost!
ac
Fume curtain and accel pedal return spring Naplm00 Wanted 6 December 28th, 2012 04:40 PM
anr1419 200tdi rhd defender accel cable Naplm00 Wanted 2 October 2nd, 2012 09:29 AM
Driveline Vibration Issue - Possible Root Cause (some people are crazy...) pmd Misc. Chit-Chat 2 January 16th, 2009 09:23 AM
Driveline Vibration johare Defender Technical Discussions 20 March 31st, 2006 09:27 PM
Driveline Clunk in early '94 D90 Hans Defender Technical Discussions 8 November 25th, 2003 09:43 PM
