AC water leak - Defender Source
Old June 11th, 2005, 11:43 PM
89classic
Matteo Gruelle
BLK 1997 Defender 90 #903
AC water leak
any suggestions on ac water dripping into front passenger foot well on 97
Also I know it is not rain or outside water- I get 0 leaks, even it Pittsburgh-
Thnks to alan elliot's cityside garage and badger coach works
Old June 12th, 2005, 12:34 AM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
There is a drain tube that can get kicked out. Look under there and you will see where it connects. Mine was doing the same thing until I reinserted.
Old June 12th, 2005, 01:21 AM
I also added a hose clamp to prevent it from falling off again.
ac, water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
