AC Temp Switch and Wire - Defender Source
Old July 14th, 2010, 09:10 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Have a brand new fascia for my AC and it has the wire that is supposed to go from the temp switch to the fins in the blower unattached. Wondering how to attach it to the temp switch.
Old July 15th, 2010, 09:53 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Nothing? I'm tired of sweating to death in my truck help a sister out.
Old July 16th, 2010, 08:59 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Look on the top cover of the temp switch
Old July 16th, 2010, 09:06 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I thinkjI figured out where it attatches it just looks like it should be soldered in place. The coil appears to be a tube and there is a part of thw switch were it should attach. Can I just make the hole on the swithc bigger and instert the tube or will this not work?
Old July 16th, 2010, 10:09 AM
I have the same switch ... to be honest I'd find an AC engineer to look at this ... or if I were feeling brave carefully dismantle the switch and see how to unsolder the remainder of the old tube - you need to be really careful as you need to determine how it fits together without breaking it further.
ac, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Major Wire problem-- dash dissasembly. Need help. Ignition Mallory Unilite Heath Defender Technical Discussions 22 August 29th, 2007 12:35 PM
Warn XD switch wire coding? dmarchand Defender Technical Discussions 0 January 13th, 2007 11:18 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
