AC stopped working. - Defender Source
Old September 22nd, 2010, 09:09 PM
TxEddie1111's Avatar
TxEddie1111
Eddie
Discovery
AC stopped working.
My AC just quit working when I stopped and then restarted after a store visit. It appears to be electrical. I dont see an "AC" fuse name labled in the box.
Any help would be appreciated.
Thanks!
Eddie
Old September 22nd, 2010, 11:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
stop cooling ? stop blowing ? can you hear the compressor clutch engaging ? you have to be a little more specific.
- Charles Eames
Old September 23rd, 2010, 08:09 AM
TxEddie1111
Eddie
Discovery
JFD, thanks and you are right. There was simply "nothing" no clicks, sounds, nada.
AND, since I am in Houstonn and no AC is just not an option, late last night, I unscrewed the bracket where the two AC control switches are mounted and the "on/off, fan speed" switch had a wire that had come off the terminal; re-attached it and presto, AC again.
So I am good.
However, that particular wire terminal was "burnt" looking and a bit melted; obviously had heat to it. It didnt appear as though this just happened (dusty, etc) but posibly was happening over a long haul. Any thoughts? Normal? Problem brewing? Need replacing?
Thanks!
Eddie
Old September 23rd, 2010, 09:28 AM
So I am good.
Thanks!
Eddie
Our A/C system is heavily dependent on neg pwr resistance signals to control everything right. I have a bad connection throwing the A/C ECU off. I would replace that connector. pop it out, put a new end on it, and push back in.l
Old September 23rd, 2010, 11:57 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
what he said and check your fuses for the right amps too.
- Charles Eames
Old September 23rd, 2010, 03:27 PM
TxEddie1111
Eddie
Discovery
Awesome, thanks guys.
Eddie
ac
AC Compressor and Blower Just Stopped Raleigh D90 Defender Technical Discussions 8 September 3rd, 2013 03:58 AM
Indicators stopped working ... leastonce Defender Technical Discussions 1 November 2nd, 2009 10:25 AM
NAS 90 Used AC System early 95 working SafariHP The Vendors Loft 0 October 26th, 2009 08:36 AM
Complete working AC system off of a 1995 D90 evilfij For Sale - Parts 18 June 7th, 2009 09:06 PM
95 AC complete and working evilfij For Sale - Parts 7 October 4th, 2004 03:55 PM
