AC relay in passenger area? - Defender Source
Old July 18th, 2005, 09:53 PM
artm
Arthur Maravelis
97 SW
For the last couple of days I've noticed a clicking sound every 2-3 seconds or so whenever the AC is on and has been working for a while. It's coming fromthe passenger side area so is there a relay there?
Also, today after 1/2 hour with AC on the engine stalled at a stop and the temp gauge read a bit past center. I restarted, shut the AC off and turned on the heater to bring the temp down.
Back in the driveway, the AC comes on when the AC's on but I didn;t hear the clicking after 15 minutes at idle with the AC fully on.
Finally, the AC fan will stay on for a minute or two after the engine's off but not all the time. I assume this is normal, happening only when it's very hot?
My thought is that there's a fan relay in that area and it's failing.
ac, relay
AC compressor relay sherpamike Defender Technical Discussions 3 September 6th, 2009 02:55 PM
1995 AC circle vent on passenger side evilfij Wanted 6 February 27th, 2009 11:29 PM
Where is the Fuel Pump relay on a 94 with AC? PCRover Defender Technical Discussions 9 May 27th, 2008 06:19 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
AC wire loose in passenger footwell artm Defender Technical Discussions 3 November 25th, 2003 11:43 AM
