ac recharge issue - Defender Source
Old September 18th, 2011, 01:18 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
ac recharge issue
ac recharge issue - I don't have not enough pressure in the system to turn the compressor on. how do I bypass to start the compressor? Thanks for the help
Old September 18th, 2011, 09:19 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
You need to disconnect the trinary switch connector down by the dryer and short out the pins for the low and high pressure. I only have wiring diagrams for a 97 so I don't know which of the pins are what... but if you get it right the compressor will come on regardless.
Another option is to "hot wire" the compressor clutch, it's a single wire that you put 12 volts on.
But the real question is why do you need to in the first place? The reason there is a low pressure switch is because the compressor is lubricated by refrigerant. If there isn't enough in the system you will likely damage it.
ac
AC recharge td5 Ben01 Defender Technical Discussions 2 July 14th, 2011 11:48 AM
AC Recharge - Valve size d90xjay Defender Technical Discussions 0 June 8th, 2006 11:51 AM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
