AC re-charge - Defender Source
Old July 8th, 2015, 01:14 AM
brooks1thompson
brooks thompson
none
AC re-charge
I just recently bought a 1988 Defender 110 with AC. My old pump was seized so I bought another older one that works but there is a leak in the line. My question is if I fix the line how do I fill the system? The adaptor does not seem to work with any over the counter re-charge systems. Do I need a special adaptor?
Old July 8th, 2015, 01:24 AM
You will need the system evacuated and then recharged with whatever proper refrigerant.
Old July 8th, 2015, 03:33 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Old R12 systems used 1/4" SAE threaded flare fittings, the newer R134a fittings are a barb and are often retrofitted onto the old R12 fittings.
I'd be doing an oil change on the compressor, keep everything closed as much as you can, get a new dryer, keep it capped and only change it when you get the system evacuated.
Even the old 5GS mineral oil is hygroscopic so everything needs to remain closed and clean.
I've seen mineral refrigeration oils looking almost fluro yellow from the amount of moisture they've absorbed, let alone how bad POE's and PAG's become when exposed to the atmosphere.
Old July 8th, 2015, 08:47 PM
brooks1thompson
brooks thompson
none
Thank you!
ac
Split charge vs parallel set up MUDSUX Defender Technical Discussions 10 March 9th, 2010 04:18 PM
Wiring questions for split charge system aclarke Defender Technical Discussions 5 April 23rd, 2007 04:39 PM
To charge or not to charge . . . Bozman Defender Technical Discussions 2 March 5th, 2007 10:29 AM
