AC question - Defender Source
Old March 8th, 2004, 09:53 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
AC question
My d-90 was making a very loud whining noise that with the help of this board we connected it with the ac compressor belt. I'm not sure if it is the compressor or the belt or a pulley. I cut the belt off last fall and the noise stopped. I was wondering:
1. what belt should I buy and how do you install it. I have a 94 with the 95 ac style system.
2.How and what should I lubricate to try to eliminate the whining.
Thanks everyone.
Old March 8th, 2004, 10:10 AM
The AC system should lubricate the compressor. It could be that your AC system is low on refrigerant. As far as the belt, Just try the auto-parts store and try getting a belt for a 95, if not try the 94 belt, they may be the same.
Old March 8th, 2004, 10:14 AM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Mike,
The refrigerant is fine. How do you install the belt? Is there a trick to it or is it straight forward. Someone mentioned to me last year that you can grease something but I can't remember if it was a pulley or the ac compressor itself.
Old March 8th, 2004, 10:28 AM
You can grease the pulley but not the compressor as I have been told the compressor should be lubricated by the refrigerant. I loosened the tensioner to put the belt on, there is one bolt that holds the tensioner in place.
Old March 8th, 2004, 10:30 AM
Campbell's Avatar
Campbell
Rich Campbell
ac
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
