AC leak... - Defender Source
Old October 10th, 2010, 04:44 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
AC leak...
I noticed a pin hole leak cause by chaffing in my low side of my AC system... It the really long pipe.. Has anybody ever JB welded a leak like this...
Old October 13th, 2010, 12:58 PM
tgraham's Avatar
tgraham
Travis Graham
1994 Defender 90
Not sure about JB Weld, but when I took the low side hose from my '95 system to get a fresh hose fitted, they patched the wear in the metal fitting at the same time. You may want to try the same.
Travis
Old October 13th, 2010, 02:12 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
you can weld it, we do that all the time down here .
- Charles Eames
ac
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
