AC Install - Should i Do it?? - Defender Source
Old June 2nd, 2016, 11:58 PM
kurtisblo's Avatar
kurtisblo
Kurt
1991 Defender 110, LHD 200TDI
My 1991 D110 200tdi is getting some work done in the UK. I reached out to CoolAir Logan (I believe they supply the AC units that Rovers North Sells) and they gave a quote to install under dash AC in my truck for $3,700 installed. Work would be done in the UK at their factory. What do you think? Is this a reasonable price? Seems like a lot of $$ but I would really like to have AC. I don't have the skills to self install so I would have to pay a shop to do it once the truck is stateside.
Looks like the kits alone are around $3,400 on Rovers North.
Old June 3rd, 2016, 12:10 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I love having AC in my 110 200tdi. It is routinely 100F where I live in the summer. Makes it enjoyable. And I went a used OEM system, cold as can be but if I was to do it again I would look at a custom system with better vent placement and second row AC (or add in that unit from RN)
Old June 3rd, 2016, 12:21 AM
kurtisblo's Avatar
kurtisblo
Kurt
Thanks. How much was your unit? What's wrong w the vent placement and does it affect your leg room (I'm 6'4")?
They did quote me to do a read unit as well. Does that take the place of a middle rear seat??
Old June 3rd, 2016, 07:03 AM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I installed the OEM system and I think it's lousy. If I had it to do over I probably wouldn't.
Old June 3rd, 2016, 09:06 AM
If you want it then get it! It's only money.
Old June 3rd, 2016, 01:07 PM
kurtisblo's Avatar
kurtisblo
Kurt
Thanks. Another question. If I put in the AC, would I still have room in the 200tdi to install an upgraded intercooler to try and get a little extra juice out of my engine?
Old June 3rd, 2016, 01:11 PM
lol...my mother used to say the same thing...it was a sure-fire way to stop me from spending money
Old June 3rd, 2016, 02:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Intercooler isn't going to suddenly make a 200 tdi less of a tractor. You have multiple threads going on at once on AC.
Why don't you go sit in a local defender with AC to figure out the leg room issue then if you are okay with it make your decision if you even want it.
Personally I would open the windows and leave the AC out.
Old June 3rd, 2016, 02:34 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I know of a tdi with standard size cooler and ac and it runs well. The bigger cooler will allow you to turn up the fuel but then that another whole can of worms with a tdi you'd need to get comfortable with. Personally it doesn't take much getting comfortable in the middle or right lane and letting the engine do what comes natural.
Old June 3rd, 2016, 02:46 PM
kurtisblo's Avatar
kurtisblo
Kurt
Thank you for your feedback. I am with you on this. Getting ahead of myself.
Yes, sorry about the multiple AC threads.
Old June 6th, 2016, 12:38 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Will have AC installed prior to importation cause issues with CBP?
Jimmy Buffett
Old June 6th, 2016, 12:42 PM
phoenix37's Avatar
phoenix37
john
no...most of the Arkonik trucks coming in have aftermarket a/c installed.
Old June 6th, 2016, 01:24 PM
I would not worry about it. Unless you put a different turbo on, that can produce a lot more boost, a larger intercooler will do nothing for you. I've tested larger intercoolers at stock boost levels and there is no change is possible power levels.
Old June 6th, 2016, 04:50 PM
kurtisblo's Avatar
kurtisblo
Kurt
Ok. Good to know. Thank you
Old June 6th, 2016, 05:28 PM
"does a/c effect leg room"
Most assuredly. I'm 6'5 and there have been several trucks we have installed a/c in that I was literally operating the clutch pedal with my left big toe afterwards.
Old June 6th, 2016, 05:35 PM
kurtisblo's Avatar
kurtisblo
Kurt
"does a/c effect leg room" Most assuredly. I'm 6'5 and there have been several trucks we have installed a/c in that I was literally operating the clutch pedal with my left big toe afterwards.
Thanks. Would extended seat rails help mitigate this issue?
Old June 6th, 2016, 05:38 PM
cdb
Clark Bowen
A/C was the most useless modification I ever did to my 1994 D90 soft top - but it might be better in a hardtop.
I bought my system about 9 years ago from Rovers North and had it installed. Passenger froze and the driver roasted because the system was clearly designed (and poorly so) for a right hand vehicle.
My total cost came to about $5,000 so $3,700 sounds cheap, but what happens if you need service? Also, how good are the mechanics who are going to install it?
If you have a 200/300TDI and are using the a/c you will have to shut it off when starting out in first gear on steep inclines or the engine will stall. I had a modified 300 TDI and 4:11 gears and it still stalled.
Also, the a/c radiator sat between a large aftermarket intercooler and the stock engine radiator and so I had problems with air flow and cooling.
All in all a waste of $5,000.
2011 RR HSE -
2001 GMC 2500 4wd
Old June 6th, 2016, 05:43 PM
Yes the ones mud UK sells. Use the second set of holes (there are two), ie set the drivers seat back as far as possible.
Another suggestion if your truck still has the yachtsman's wheel is to go to a smaller diameter steering wheel so that as a larger driver you have a little more room, the vehicle drives tighter with a smaller wheel and you do not need the leverage that the huge wheel was designed to give if you have power steering. The seat rails lift the drivers seat about 1.25 or so and that is the space between your thigh and the lower edge of the steering wheel.
Old June 6th, 2016, 06:23 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
You could do this and save about $3650.
https://youtu.be/ITtlxjvLQis
Old June 6th, 2016, 08:46 PM
kurtisblo's Avatar
kurtisblo
Kurt
Originally Posted by Vunkle View Post
You could do this and save about $3650. https://youtu.be/ITtlxjvLQis
That is an awesome swamp cooler. Perfect for sleeping in back of truck for burning man
Webasto Gas Heater Install - where should I put it RedD90 Misc. Chit-Chat 14 February 17th, 2012 09:42 PM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
how much should I pay for a starter Campbell Defender Technical Discussions 5 November 4th, 2003 02:38 PM
Ive got a stock d90 and 500 dollars, what should i get? Platinum992 Wanted 8 October 27th, 2003 10:45 PM
BFG mud terrain 33x12.5x15 what should I pay? artm Wanted 3 October 11th, 2003 01:19 PM
