AC Install Assistance - Defender Source
Old August 14th, 2015, 02:31 PM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
I am looking for an AC upgrade (no AC to some AC) in an 88 3.5 V8 110. One option I am looking into is a 94 NAS takeoff version. What will be my fitment issues?
Old August 14th, 2015, 06:42 PM
20 year old worn parts with limited spares availability ...
Old August 14th, 2015, 07:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Why not just get a VA under dash system, condenser, pump & make your own hoses up.... prob get the lot new for under a grand and it'll work, be serviceable & reliable.
http://www.summitracing.com/int/part...uy-a/overview/
Old August 14th, 2015, 07:29 PM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
Thanks for the feedback thus far, but will a 1994 NAS AC system fit my 1988 110 with a v8? What kind of modifications should I anticipate if any?
Old August 15th, 2015, 10:22 AM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
Bump.
Old August 16th, 2015, 05:20 PM
As long as the 88 is LHD then you should be OK - physically. You'll probably need to use the AC compressor mount and tensioner from the 94 at a guess. The belt drive should be OK.
You'll need an over temp sensor in the water hose ... either use a x-eng temp switch in a hose or use the genuine article from the 94.
The wiring is fairly straight forward and any competent auto electrician should be able to figure it out.
If you have the Davia system then prepare to swap in a replacement compressor ... they are NLA and so you should source an alternative and have the appropriate hoses made up. You'll have to do it soon as the original is 20 years old like I mentioned earlier.
The condenser 'radiator' is probably a bit fragile by now ... consider sourcing a replacement.
You'll need a new drier - the canister that goes down on the frame.
The 94 AC connects to the ECU to signal the additional load and let the ECU compensate ... assuming yours in a non-efi you won't have to do this. If yours is EFI then depending on the model you may need to hook it up.
I went through all this crap to retro fit AC to by 95 from a 94. Frankly I would buy a new kit and save myself the hassle. You can get it to work ... but it will break and when it does work it's barely adequate in a 90 and certainly inadequate to cool more than the area around the front seats.
Can it be made to work ... yes ... is it a reasonable approach ... nope!
ac
Inspection Assistance - San Diego speedway16 Misc. Chit-Chat 20 January 15th, 2011 12:15 AM
Color check: need assistance upon3 Defender Technical Discussions 9 February 2nd, 2010 11:36 PM
Assistance with Fresh Air Vent Fan JRW Defender Technical Discussions 3 November 17th, 2008 03:31 PM
shipping assistance mountainviewrover Misc. Chit-Chat 9 April 22nd, 2008 08:50 PM
what is the best Roadside assistance? jorge Misc. Chit-Chat 7 July 29th, 2004 10:16 PM
