AC/Heat Install Question - Defender Source
Old July 17th, 2012, 01:35 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
When you install AC in a truck, won't it cover up the lower dash heat vents? Or is the back side of the evaporator open to allow heat to enter it?
I ask because the aftermarket AC kit I can get has a option for heat and even defrost.
Cheers!
Semper Fi!
Old July 17th, 2012, 01:58 PM
texrover's Avatar
texrover
Jason
I was just wondering the same myself.
Curious to see replies....
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 17th, 2012, 01:59 PM
the 94 unit has holes cut in the back
Old July 17th, 2012, 02:00 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
The factory plenum has notches in it for the heat vents. I imagine aftermarket units would cover them up as you said.
Old July 17th, 2012, 02:04 PM
nothing a hole cutter can't cure
Old July 17th, 2012, 03:04 PM
The Elite AC kits have a foam-sealed opening to the heater vents. The heat blows out two vents that are built into the bottom of the plenum. likely any other under dash kit intended for defenders would be the same way.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old July 17th, 2012, 09:36 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On the LHD for the aftermarket kits they cover the rH vent but re-direct it down lower. The good part is you can also use the fan on the A/c unit to blow heat out of all the vents. Works great.
Land Rover 110
Old December 11th, 2016, 07:45 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Curious if there needs to be any modifications to the ducting to do this. When I have the heat on and turn on just the fan for the AC vents it doesn't blow heat, just ambient air.
Old December 11th, 2016, 09:03 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
My to-be-installed CoolAir unit has pass-thru ducts, with foam backers to the stock heater air box, and goovy circular adjustable flaps so you can move the heat wherever you want.
ac
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
Bilstein Install Question 48vphantom Defender Technical Discussions 7 September 18th, 2006 04:08 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
