AC Fuse Box Cover? - Defender Source
Old April 19th, 2013, 05:07 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
AC Fuse Box Cover?
Is there a different main fuse box cover for trucks with AC? There is no way a non-AC cover fits....
Semper Fi!
Old April 19th, 2013, 05:52 PM
Pretty sure they're the same. I know mine is a super right fit (I have A/C) though. I think I usually put it in 4th gear then slide the fuse box cover up and over (to remove) or over and down into place when installing. The cover is plastic and bends a little to get it down in there. Maybe the A/C was mounted too low, in which case I could see why it would be even more difficult to get down in there.
Old April 19th, 2013, 05:59 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, this one isn't even close to fitting, seems odd.
Semper Fi!
Old April 19th, 2013, 06:13 PM
Pics? Can you get it on without the transmission boot or arm on? Is there a super thick transmission cover on, etc.?
Here is mine without the cover on, but it does fit in there.
Old April 19th, 2013, 06:50 PM
Wolf Fabrication
Sterling Archer
'08 D3
Here's mine. It's not even close to fitting. So the big question is whether the fuse cover is different between 94 and 95? I've retrofitted a 94 AC system in to a 95, and the 94 cover doesn't fit.
Can someone post a pic of the '94 cover?
ID:	70398   Click image for larger version
Semper Fi!
Old April 19th, 2013, 07:07 PM
You have to trim the top of the cover to fit it in a 94 system.
Old April 19th, 2013, 07:10 PM
Wolf Fabrication
Sterling Archer
'08 D3
That's pretty much what I was thinking, just wanted to make sure there wasn't another cover before I started cutting up a good cover!
Semper Fi!
Old April 19th, 2013, 07:15 PM
Someone might have one pre cut.
Old April 19th, 2013, 07:33 PM
CDeWan
Clay DeWan
5.3L beastie
what Ron said
They are different. Not AC's are taller and 94 ACs covers need to be cut. There might be an inside scoring line on where to cut or see if you can post in the wanted section.
Old April 19th, 2013, 10:18 PM
I swapped mine with the person I bought the AC from.
Old April 24th, 2013, 11:56 AM
CDeWan
Clay DeWan
5.3L beastie
Wolf,
Did you find a cover?
Old April 24th, 2013, 12:02 PM
Wolf Fabrication
Sterling Archer
'08 D3
I believe I did. I left the deal with my customer who's making the switch
Cheers
Semper Fi!
Old April 24th, 2013, 01:05 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Here is a picture of the instruction manual for the older Diavia systems. I think they made the factory set ups back in the day.
Name:	Diavia fuse box cover.jpg
ac, cover
Cover fuse box for defender new in box and lev-o-gage sr jonathon For Sale - Parts 2 December 3rd, 2012 06:39 PM
new fuse box cover mattdh For Sale - Parts 10 March 29th, 2006 01:24 AM
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
Engine Fuse Box Cover thug1313 Wanted 3 April 20th, 2005 07:26 PM
