AC Fuse - Defender Source
Old July 9th, 2014, 02:19 PM
toona's Avatar
toona
Toona
1994 D90
AC Fuse
Searched for this and couldnt find anything...
I blow the 30w fuse whenever running the AC.. I can get it to run for 10 mins if I run it as low as possible, but it'll eventually die when idled. If I crank it, itll blow instantly. Any ideas? Have replaced it a bunch...
Its also dripping on the passenger well.
Old July 9th, 2014, 02:23 PM
first look at the grounding
Mark Kellgren
KM4BOR
Old July 9th, 2014, 02:33 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Seriously, you're using your air already! it's not even 110 out yet! Is it factory or after market AC? I suppose you'd have to take it apart for the ground in any event...
Old July 9th, 2014, 02:41 PM
No dissassembly required for checking the ground. It's a seperate wire on the harness that installer grounds to frame. Mine is grounded on the fuse bus. Also check the main harness connector (big and brown).
Don't listen to Bill. He doesn't use A/C. He's preparing for life in the apocalypse after the EMP attack when the A/C ECU gets shorted out (but he does't like TDI's...go figure).
Of course, he believes in having two of everything, so don't underestimate him. He probably has a spare D90 in a faraday cage in his bunker.
Mark Kellgren
KM4BOR
Old July 9th, 2014, 02:47 PM
Bill Larson
Bill Larson
Whatever dude...my entire truck is a rollin Faraday cage...
Old July 9th, 2014, 02:50 PM
See how cranky he get's when he drinks Starbucks?
Mark Kellgren
KM4BOR
Old July 9th, 2014, 03:23 PM
Dude: 30w is less than three amps. Think that's your problem.
Old July 9th, 2014, 03:46 PM
toona's Avatar
toona
Toona
1994 D90
Thank you all..
Mark - will check the grounding, much appreciated
Bill - not using it (have the doors & top off) but see we have triple digits starting next wk
King - its the 30A (Green) fuse
ac
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Strange Fuel Pump Fuse Problem mhill Defender Technical Discussions 6 July 11th, 2005 04:23 PM
94 ST Fuse Panel Cover mfreeman17 Wanted 0 June 28th, 2004 01:30 AM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
