AC Fan Speen, Only Blows on High - Defender Source
Old April 18th, 2013, 06:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
95 D90.
Anyone ever experienced this? The AC fan speed only blows on high. I've confirmed the switch itself is good, and with each turn of the switch the proper signal is sent to blower motor resistor. Only high works, no low or medium. Looking at the resistor (it's wide open) I can't see anything wrong with it.
Semper Fi!
Old April 18th, 2013, 08:49 AM
Wolf Fabrication
Sterling Archer
'08 D3
Figured it out. The integral fuse is blown...
Semper Fi!
Old April 18th, 2013, 09:54 AM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Replacement part # of just a fuse? Mine does the same thing.
Old April 18th, 2013, 10:01 AM
Wolf Fabrication
Sterling Archer
'08 D3
My plan is just to solder in a new fuse. I'll post a few pics later today when I do it.
Semper Fi!
Old April 18th, 2013, 11:03 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
AC in a Defender.....thats just silly......lol...
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 18th, 2013, 11:31 AM
Wolf Fabrication
Sterling Archer
'08 D3
Soldered in a new fuse and blows like a champ! (...That's what your mom said)
ID:	70308   Click image for larger version
Semper Fi!
Old April 18th, 2013, 09:09 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
The bigger joke is that you'd want to have it in any position other than High and all the way on cold...
If you need the AC you need more than the stupid POS will put out anyway lol
ac, fan
AC compressor pulley for fan hub? Axel Defender Technical Discussions 0 March 4th, 2013 08:58 PM
300Tdi / Fan cowl / high heat triple9music Defender Technical Discussions 13 June 6th, 2012 03:16 AM
AC Condensor Fan Brackets aosias Defender Technical Discussions 2 July 19th, 2010 09:10 AM
ac condensor fan operation stephen Defender Technical Discussions 2 June 30th, 2008 08:32 AM
