Hi all,
I am hoping someone can help with a wiring issue I am having with my AC.
I have a 1997 D-90, auto with 4.0 v-8. My ac hose was leaking, replaced it and ordered a new drier. The new drier replaced the old drier and now has fine thread where the old one had coarse threads. Old cut out switch will not work with the new drier. So I ordered a new cut out switch for the new updated drier, from local dealer on both. The new switch shows up and is updated also. It does have fine threads, but it has a harness, 4 wires and two plugs built into it. The new switch has two blue wires going to the same connector and two black/green wires going to the other connector, but no diagram on how to hard wire it up to the truck harness. I can not get a diagram for the life of me on where to but these up.
Please, someone help me with this. I can not find an old style drier either to bypass the new, updated one.
The new switch number is 8510066 and new drier number is stc 4851.
Surely I'm not the only one to run into this issue.
Thank you in advance.
