AC Doesn't Blow Cold - Defender Source
Old October 7th, 2012, 09:53 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
Whenever I turn on the AC in my 95 D90 ST, the AC doesn't blow cold air. This has been happening for a few months now. It worked fine before. Could it be as simple as recharging the AC or might it be something more serious?
I apologize if there's already been a similar thread to this. I searched and couldn't find anything.
Thank you,
Charles
Old October 7th, 2012, 10:24 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
No freon, you may have a leak in A/C circuit.
- Charles Eames
Old October 8th, 2012, 08:53 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Do you hear the "click" and feel the load on the engine when you turn it on? If the compressor is not engaging, it won't get cold.
Old October 8th, 2012, 08:57 AM
87 D110 (Ruby)
Worry about it in JUNE next year ....check your heater now!
Old October 8th, 2012, 09:06 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
And compressor won't engage if it doesn't have refrigerant. Add refrigerant and do the identify-leak-via-UV-light route.
Mine seems to lose refrigerant every couple years and I think the leak is very small. Mildly annoying.
-Ren Ching
Old October 8th, 2012, 10:59 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I would vacuum it down and see if it holds negative pressure. If it holds you don't have a leak. Then re-charge it. I have the tools in Northern NJ of you need them.
Old October 8th, 2012, 01:44 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Mine was plugged with contaminants from the failed drier in the regulator thingy near the evaporator. So, needed to have an ac shop custom make ac lines to fit the genuine drier as there are no ac lines that fit any drier on V8 trucks. Hope you are just low on 134....or youll be out 400-700.
Old October 8th, 2012, 07:13 PM
Hinckley423
Charles Joerss
1995 D-90 #2812
I appreciate the offer. I'l let you know if I need them. Thank you
------ Follow up post added October 8th, 2012 07:14 PM ------
Thank you for all of the help. I appreciate it.
ac
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
Cold Weather Starter Problems boshea Defender Technical Discussions 9 October 25th, 2005 04:35 PM
a/c not cold jblieb Defender Technical Discussions 1 September 15th, 2005 10:34 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
