AC differences - Defender Source
Old October 31st, 2006, 12:53 PM
Andrew Vick
Andrew Vick
95 D90
AC differences
What are the differences, if any, between 95's and 97's? Are they the same?
Old October 31st, 2006, 01:55 PM
No.
97 is a completely different system from 95.
97 was an add on system that has different everything and does not include the compressor. 95 (that actually came in very late 94) is a complete system. The 94 system is different still.
You could run a 97 on a 95 but you need a compressor and brackets off of a 94/95 or a RRC. With the RRC compressor you may have to convert to R134a (all D90s are R134a, only 93 110s are R12), but I think it would be ok as is.
Old October 31st, 2006, 02:06 PM
Andrew Vick
Andrew Vick
95 D90
A bit confusing. How about a 95 system in a 97? No dice?
Old October 31st, 2006, 02:58 PM
Not sure. Might interfere with the center consol.
Old October 31st, 2006, 03:05 PM
I highly recommend a 97 system in a 97 - it is designed to plug right into the main body harness. Its also a nicer looking system.
Old October 31st, 2006, 10:11 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
The question is...do you have two plugs on your passenger firewall that are plugged into blind spade lugs on the firewall? if you do, I would suggest that at least the electrical problems are a non issue...I have both an old take-off AC system from an earlier d90 and a 95 kit that I got from RN...they're essentially the same but the 95 is a cleaner looking design...but they both fit the underneath of the dash...the earlier system looks like it was riveted in and the 95 is pretty much a bolt in on the interior...as to the engine bay, from what I hear many 90s have the AC compressor installed, if so , then you are stylin...if not, you gotta get that done...I have a spare bracket and compressor because I ordered my 300Tdi engine with them and so now have extras...anyway, more specifically, what is your situation and what do you want to do?
Old November 1st, 2006, 07:43 AM
Andrew Vick
Andrew Vick
95 D90
I will check those firewall connectors. I am selling my AC from a 95, and one person who is looking at it has a 97. Neither of us had any idea if it would work. Thanks for all of your suggestions.
Old November 1st, 2006, 09:55 PM
redrover
Guest
Posts: n/a
Andrew , any interest in meeting a couple of us in Moab this weekend for a final trail trail run before its all snow ? JP
Old November 2nd, 2006, 07:29 AM
Andrew Vick
Andrew Vick
95 D90
I'd like to, but probably too short notice and I've bee gone too much. I really appreciate the offer, though!
ac
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
serial # differences from lt85 and lt77 draaronr Defender Technical Discussions 1 August 30th, 2004 11:56 AM
Differences between metal and fiberglass top jaherring Defender Technical Discussions 5 June 19th, 2004 05:59 PM
