AC Condensor- smaller size? - Defender Source
Old July 21st, 2010, 10:19 AM
aosias's Avatar
aosias
Alexandra
1995 D90
The saga continues. I have borrowed a condensor to have brackets fabricated for my hot mess and low and behold it's a different condensor. So, I have a smaller condensor for my AC kit and haven't been able to locate how this condensor mounts to the truck. I know that there are at least 4 different kinds of condensors based on the system you have, etc. Photos attached of the borrowed full size condensor and the mini one I have. Also a close shot of the only bracket attached to mine.
I am looking for some photos/thoughts of how to install this smaller condensor.
Alex
ID:	29523   Click image for larger version
Old July 21st, 2010, 11:00 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I have the same condenser as yours on my old 110. I can try pictures or you can come look at it if you like. Funny -It started blowing warm so I added refrigerant last night. The darn condenser has a leak. Do you suppose they can patch a leak in a condenser like they can with a radiator?
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old July 21st, 2010, 11:15 AM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Where did you get that smaller condensor I need one? I am doing AC on my series and with the IC I only have room for like 16"x16". Do you have the measurements?
Old July 21st, 2010, 11:32 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Photos would be great but I can look too. I owe you some beverages too! Have no idea on the patching, let me know if you find out anyting since that will likely be my next mess...
Will measure and post those for you. If you have the full size in similar used condition I'd be willing to swap but then you'll be in a similar boat as I am with the bracket mess. This came with a kit I purchased off the board almost 2 years ago.
Old July 21st, 2010, 04:02 PM
bcourtney's Avatar
bcourtney
Robert Courtney
I do and no problem on the bracket I have to make everything for this conversion. I'll take a picture
Old July 21st, 2010, 07:05 PM
aosias's Avatar
aosias
Alexandra
1995 D90
It is 18" from side to side and 14" in height.
Old July 22nd, 2010, 11:02 AM
bcourtney's Avatar
bcourtney
Robert Courtney
That will work. Here is mine.
Old July 22nd, 2010, 05:38 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Pictures of the fittings
ID:	29572   Click image for larger version
Old July 22nd, 2010, 08:07 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not sure if this helps any since mine is a 97 but the larger of your 2 condensors looks very similar to mine. Have attached some pics of how mine mounts to the truck and the part #s. Mounts to the same points as the radiator using 4 brackets. Might be useful, might not.
HTH
Ian
ID:	29575   Click image for larger version
ID:	29577   Click image for larger version
File Type: pdf Cooling, Heating and Air Conditioning.pdf (64.9 KB, 67 views)
Old July 23rd, 2010, 09:18 AM
Rod Hayward
Rod Hayward
95 D90 Green #2288
I finally got a chance to pull my condensor out last night, Alex. Turns out its the big one. What can I say? Beer goggles? Sorry I'm no help. Good luck.
Old July 23rd, 2010, 09:42 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I don't know if those fittings will work with the hoses that I currently have.
Thanks Ian that's exactly what I needed.
Thanks for looking Rod.
Alex
Old July 23rd, 2010, 09:49 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Torch welding. They do that all the time down here. The result is not very nice but it works.
- Charles Eames
ac
D110 rim size? Robbie Donaldson Misc. Chit-Chat 17 August 6th, 2005 11:18 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
What size socket? kit Defender Technical Discussions 1 February 7th, 2004 02:26 AM
5 Swamper TSL's, size 38/12.50/15 for sale or trade TyziskBen For Sale - Parts 0 November 6th, 2003 04:34 PM
