ac concerns - Defender Source
Old July 2nd, 2004, 01:25 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
ac concerns
I am having a problem with my drain tube for the a/c unit in my 90. The original one broke off leaving a ragged hole in the bottom of the unit inside the cab. It was draining on the floor so I tried to insert a tube with a threaded end and it seems to be working ok. Sometimes it drains water other times it doesn't. It is leaking at certain points at the bottom of the condensor.(very small drips) The water doesnt seem to drain as well as before. I was just concerned about what if any damage can be done if all the water isn't draining correctly. Has anyone solved this issue?
Old July 2nd, 2004, 02:14 PM
Well I thought about this for a few, If I'm off hear or sound off then someone let me know but:
Water in the AC system is from the moisture in the air that is being blown across the condenser condensing on the fins, then becoming water, dripping off the fins and draining out the hose in the bottom. So everything in the plastic box that contains the condenser should by design be allowed to get wet.
Clear as Mud?
ac
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
