AC compressor ticking - Defender Source
Old March 1st, 2007, 05:31 PM
artm
Arthur Maravelis
97 SW
On my 97 D90 with 107k miles, I now have a ticking sound, noticeable from inside the cab and appears to come from the passenger side of the motor.
It comes on soon after a start and continues, independent of engine speed. You can listen to it here:
http://home.earthlink.net/~amjas/D90_outside.wav
recorded off the passenger side, hood closed.
The rate is very fast for any single item source so started looking elsewhere. Had the belt removed and it went away. The source appears to be the AC compressor. There is a bit of play on the pulley, Compared it to another 97 with absolutely no play.
Anyone else ever with this problem?
Can the compressor be repaired (clutch swap) or is a replacement in order? I just started looking for replacements and $255 seems pretty good for a reman job. Looking into a NAPA equivalent with a lifetime warranty.
Old March 2nd, 2007, 01:15 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Someone is selling a '97 A/C compressor for $75 (or so) in another thread right now..... Then you can look for other options if you want (repair?).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 2nd, 2007, 01:19 PM
artm
Arthur Maravelis
97 SW
Yep, thanks for the heads up. I've contacted Cliff.
ac, compressor
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
