AC Compressor source needed - Defender Source
Old April 15th, 2012, 08:20 PM
I need a Harrison V5 as fitted to GM vehicles.
Original model is Delphi / Diavia Compressor V5 Rotalock orizzontal 015124/124
Any ideas where I can source a genuine or replacement model?
Thanks in advance
Old April 19th, 2012, 07:43 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
http://www.compressor-intl.com/HTML/allxref.htm
Old April 19th, 2012, 08:22 AM
They don't have it ...
Old August 1st, 2013, 04:41 PM
kellykortman
kelly kortman
1994 land rover defender
http://www.discountacparts.com/parts...-01550_NA.html
http://www.discountacparts.com/parts...-00811_NA.html#
might it possibly be one of these. These are very inexpensive too!
Old August 1st, 2013, 04:47 PM
I had it rebuilt ... apparently it's fitted to a Kubota tractor and NLA
Old August 1st, 2013, 06:48 PM
skrufy
Tim Timmins
1987/Defender 110
Try ebay. there are several re-builders that have a lot of stock. Perhaps they have the one you need.
Tim
Old August 1st, 2013, 07:06 PM
I though they were Sanden compressors. Maybe they ran out on teh day yours was built, and they decided to fill in with something close.
-Jeff
They also fitted these to VW cabriolets I'm the 90's. I guess someone was making retro fit kits.
Old August 1st, 2013, 07:10 PM
skrufy
Tim Timmins
1987/Defender 110
If they are "new" Sanden compressors, I'd find out where they were built. Sanden has a new plant in China, and in my personal experience- are pure crapola. I bought one from an ebay seller for my '77 Porsche 930 because I am still running R12 in it- lower head pressures, less heat vs R134a. They shaft size was smaller in diameter than my original unit (for those of you who know 911s- they came from the factory with a York POS piston unit- I changed that out 20 years ago with the rotary...)that I still had on my workbench. I went with the "new" Sanden unit because it had the R12 fittings I needed w/o having to change hose ends to match later compressors, etc.... Well, after charging the system correctly, that clutch on the compressor lasted about 20 miles down the road- bearings grenaded and spewed burned grease all over everything.... The seller was good- returned my money and shipping....
There are reputable re-builders who advertise on ebay- they take your unit and re-build to OEM specs. Just a thought to consider......
Tim
Old August 1st, 2013, 07:15 PM
I had mine rebuilt in Florida. It's not a sanden but likely could be substituted for one. I live in NYC and finding little AC shops with knowledgeable people is a bit tricky.
Old August 1st, 2013, 07:34 PM
skrufy
Tim Timmins
1987/Defender 110
Jason-
I'd do a google search for a/c compressor rebuilders. Many sites have charts as to what compressor is inter-changable with what, etc, or just talk to one of the tech guys. My 930 compressor is down in Phoenix getting rebuilt by the guy who rebuilt it 20+ years ago..... there are many rebuilders- just make sure they can do yours. So many shops just want to throw a new one in there w/o trouble shooting IMHO- like the local body shop here that doesn't really do body work- they just replace whole panels... Let us know how it works out for you....
Tim
ac, compressor
Skills needed to install AC aosias Defender Technical Discussions 5 April 26th, 2009 10:41 AM
Spare Tire needed Andrew Vick Wanted 0 March 15th, 2006 01:57 PM
1994 D-90 Factory Bestop parts needed?? Adam Armendariz Defender Technical Discussions 2 March 30th, 2005 08:25 PM
manual transmission needed ember Wanted 0 August 31st, 2004 11:50 PM
What Parts Are Needed For A P/U Cab? javelinadave Defender Technical Discussions 6 October 25th, 2003 09:48 AM
