AC compressor relay - Defender Source
Old August 18th, 2009, 09:41 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
AC compressor relay
Anyone know where the AC compressor relay lives? My compressor won't come on, and I don't have 12V to the compressor with the AC turned on.
-Checked fuses.
-Checked the thermostat.
-Checked refrigerant pressure.
Turning on the AC does turn on the fan and blower.
Any other ideas?
Old August 18th, 2009, 10:12 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Did you look on the side of the blower motor (right side)? Or, possibly behind the bracket that holds the fuse panel (the goldish metal thing)?
I recall them being in either of those places.
Old August 18th, 2009, 05:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Under passenger seat in my truck.
- Charles Eames
Old September 6th, 2009, 02:55 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I seem to be having the same issue. Everything seems to be working fine and if I jumper the two wires going to the temp switch in the thermo housing the clutch kicks in and starts working. I just replaced the thermo and switch and am guessing that maybe the previous switch as bad as well as the relay? You know, so now that the switch is working, the clutch is not because of the relay.
Anyone know where to get these? I have searched but come up empty. Or is a dealer item.
BTW, There are three relays on the right-hand side of the blower motor not sure if these are the ones or not. I took the cover plate off the fuse panel but didn't see anything that might be a different relay.
thanks,
Bill
Bill
ac, compressor, relay
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
