AC Compressor Rebuild - Defender Source
Old August 18th, 2010, 12:35 AM
bd90
94 Arles Blue #1644
Does anyone know where a new compressor can be had and if not can they be rebuilt? Has anyone here had a compressor rebuilt? My mechanic said that new ones are not available.
Old August 18th, 2010, 05:46 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Brian I have just rebuilt the denso aircon compressor on my 300 to use as an on board air pump, I needed to strip it to replace a noisy bearing & fill the rear with grease.
the bearing was freely available at the local bearing supplies for 8.
I did not replace any of the seals though.
the tricky bit is removing the compressor clutch without damaging the bearing housing as the split ring clip is well hidden in the bearing housing.
there was a thread on LR4x4.com about rebuilding aircon compressors
have fun
Gren
Old August 18th, 2010, 05:52 PM
CBaldwin has a compressor. Used, but worked fine.
Old August 20th, 2010, 05:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You can rebuild an ac compressor, not really easy and you need a couple of special tools, but it can be done. Check the web.
- Charles Eames
ac, compressor, rebuild
1997 NAS Defender 90 AC kits ECR The Vendors Loft 2 December 22nd, 2009 07:18 PM
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
