AC compressor pulley for fan hub? - Defender Source
Old March 4th, 2013, 08:58 PM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
Anyone ever run a belt from the AC compressor to this pulley here, which used to support the mechanical fan?
There must be some reason no one does that. I know the factory runs it to the crankshaft pulley, via an idler below the compressor. But it seems so much simpler if I could just run it to off that nearby hub. And perhaps the factory only does it so they can run the mechanic fan?
Anyone know if the compressor belt could run off this pulley hub, assuming I had a grooved hub made for it?
That's a 200TDi motor & dual electric fans, in an 87 110
ac, compressor, fan, pulley
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 05:26 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
hub nuts jimmy salmon Defender Technical Discussions 2 March 13th, 2005 06:00 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
