AC Compressor for On-board air - Defender Source
Old June 29th, 2008, 10:38 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Lightbulb AC Compressor for On-board air
Has anyone pulled their ac out and used the compressor as their on-board source?
Old June 30th, 2008, 09:58 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I'm doing it.
Slowly
Just need to pull the line-s,decide where to place the air chucks and fab a couple of brackets.
You can find good infos on lr4x4.com BB, in the tech archive...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old June 30th, 2008, 10:42 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yup, works great.
ECR4 had it too. Worked perfect for tires, needed a bigger air tank for air tools, but it would still run an impact, you just had to let it catch up a little periodically.
Email:
Old June 30th, 2008, 09:31 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Originally Posted by Cube II
I'm doing it.
Slowly
I'm not finding it.
Originally Posted by ECR
Yup, works great.
Any site or place where i can see how to do this?
Old July 12th, 2008, 10:14 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Try this:
http://forums.lr4x4.com/index.php?sh...air+compressor and http://forums.lr4x4.com/index.php?sh...air+compressor
You will need to register if you haven't already.
Mike,
If you read this, can you shed some light on setting up the EFI/ECU to recognize the compressor is activated?
Greg
Old July 13th, 2008, 11:16 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Thanks Greg. That definitely helps.
Old July 14th, 2008, 07:00 PM
Planning on doing this myself. Why does the ECU need to know, to adjust the idle speed?
charles
Old July 14th, 2008, 07:38 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Having a difficult time finding some of the parts needed, Filters, oilers, valves, regulators, etc.
Old July 14th, 2008, 09:33 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Charles,
This was posted by Mike from ECR a few months ago:
". . . it can be . . . tied into the EFI ECU so that the engine will not flare/ stumble at idle when the compressor clutch kicks on and off. Its an easy fix.
If you want to tie it into the EFI ECU like the factory intended its easy and I can tell you how to do it."
Sounds like a good idea, if it is easy.
Old July 15th, 2008, 09:55 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
Sorry I didn't reply I've been away.
As to the parts, try and check this out:
Kilby
Michele
D90 VNTdi
[O]===[O]
Old July 15th, 2008, 12:35 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Kilby
Whoohoo
Thanks Cube.
Project will be underway soon.
There is an article on this topic in the Sept 08 (in magazine stands now) issue of 4 wheel drive and sport utility magazine. Kilby enterprises Airboss Onboard Air System.
http://www.4x4groupbuy.com/store/onb...-c-49_931.html
the Viair system looks much cheaper.
Old July 15th, 2008, 03:14 PM
ECR's Avatar
ECR
Originally Posted by Bozman
Charles,
Basically the ECU gets a signal and then once it adjusts the engine it offer a ground to run the relay or compressor clutch. Comes in on pin #27 to the ECU (power) then comes out as a ground on pin #33.
Same when you shut off the device, it makes sure the stepper doesn't go bat-shit trying to compensate and keeps the idle smooth and steady.
In a 95 D90 this is wired into your AC at the multi connector near the evap. On 94s it is in the engine bay near the heater (same place on 110s). So you can wire a relay to run the compressor clutch or if you have a 2 wire clutch just use the output for the ground on the clutch.
There are inputs in the 14CUX for the automatic gearbox and the heated windscreen, basically anything that requires the engine to adjust to a load is just putting in the right wires to the 14CUX. It can be done in a GEMS as well but its a little more work.
Email:
Old July 15th, 2008, 04:56 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
So How would I do this on a '97?
Old July 23rd, 2008, 08:40 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Parts ordered from Viair (much cheaper than Kilby and easier to deal with, ask for Shawn).
I plan on having a coupler exit from my rear crossmember. 2 gal tank mounted under the passenger seat on the frame b/w the rock slider and the frame. The more I research this the easier it appears to be. I'm sure I'm disillusioned.
Old August 3rd, 2008, 08:44 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Thanks Mike,
That is a big help.
Old August 3rd, 2008, 10:05 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I plan on having a 2 gal tank mounted under the passenger seat on the frame b/w the rock slider and the frame. The more I research this the easier it appears to be. I'm sure I'm disillusioned.
I used the air tank off a late model Range Rover Classic and fabbed up some brackets to mount the tank out board of the frame rail between the slider and the frame. It's tucked up pretty well where everything is protected. The compressor is mounted in the compartment under the passenger seat. Its similar to a Puma unit (got it from Rover Solutions at MAR a few years ago).
Here are a couple of pictures of the air tank installation:
ID:	14627   Click image for larger version
Old August 17th, 2008, 10:59 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Finished this project yesterday. Works awesome.
Cost:
Viair tank $55
Viair Pressure regulator, gauge, switch, tubing a fittings $85
Misc parts from local ACE hardware $25
Inline filter $15
Pics coming if interested.
Old August 18th, 2008, 05:47 PM
Good to hear. Would love to see pics!
Old August 18th, 2008, 07:08 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Here's the results. I am not the best at tucking things away and making everything neat but it came out pretty nice.
This is the gauge and switch:
Compressor
Pressure regulator
Tank and filter
Chuck in rear cross member
Angus and Rider sat here the whole time I worked on it
Old August 20th, 2008, 01:02 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Wow! Nice job Mike. I cant wait to see it in Moab. Go Dawgs!
Todd
'95 D90 #2206
'66 109" P/U
ac, compressor
CO2, ARB on board air! TwisteD90 For Sale - Parts 4 June 16th, 2004 11:43 PM
On board air compressor Davis Defender Technical Discussions 5 March 7th, 2004 08:28 PM
On Board Air javelinadave Misc. Chit-Chat 13 December 2nd, 2003 12:41 PM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
