AC compressor bracket on 200 tdi - Defender Source
Old August 29th, 2011, 05:01 PM
kjva
Ken Jackson
1985 110 Wagon
Just replacing a 2.25 petrol with a 200 tdi in a 110 Wagon. The 2.25 has factory fitted AC. To mount the bracket on the 200 tdi four holes need to be drilled and tapped, does anyone have a depth to drill to avoid going right through the timing cover ?
Old August 29th, 2011, 06:34 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Just did this on a 200tdi. The front two holes are outside the timing case, so no problem there. I've got an extra timing case sitting in my garage so I can measure the thickness tonight and let you know. I only had a tapered tap on hand, so I had to go all the way through so as to get enough thread for a bolt.
Old August 31st, 2011, 01:16 AM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Total depth of rear studs through which you drill is 21mm.
Old August 31st, 2011, 09:16 AM
You must drill right through the timing cover. It is not thick enough for blind tapped holes.
Old August 31st, 2011, 03:29 PM
kjva
Ken Jackson
1985 110 Wagon
That was one of my concerns as I did not want to remove the timing cover on the engine as it has just been re-built. It was suggested to use coarse thread studs.
Old August 31st, 2011, 04:58 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
I didn't remove it. Just go really slowly as you tap so as you drill and then later tap so as not to damage the timing belt. Also blow out the aluminum shavings as you go so as to limit how much falls into the timing case.
Old June 15th, 2014, 01:26 AM
D1104x4life's Avatar
D1104x4life
Seth
1983 Defender 110
Anybody have any pictures of the holes drilled in the timing housing and cover? I gather from reading the thread the holes are drilled in the cast in blocks in the upper left of the housing/cover.
Stole a York off of my 73 Minnie Winnie and plan on doing the whole OBA thing. Currently rebuilding the 200 TDi and rewiring the entire Defender. Want to make sure all the wires I will need for the clutch will be factored in too.
ac, bracket, compressor, rack, tdi
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
200 tdi defender for trade pendy Defender Technical Discussions 4 May 1st, 2012 11:26 PM
300 TDi AC kit install manual michael67 Defender Technical Discussions 5 November 29th, 2010 11:56 AM
thinking of buying 200 tdi Defender discotdi Defender Technical Discussions 3 August 27th, 2010 01:25 PM
AC in D110 TDi artm Defender Technical Discussions 2 May 13th, 2004 07:18 PM
