AC Compressor - Defender Source
Old February 23rd, 2006, 10:53 AM
lactic's Avatar
lactic
'95 D90 SW Arles Blue
AC Compressor
Will a AC compressor from a '95 Discovery fit in a '95 90? I picked up a AC system minus the compressor from a '94 Defender.
Old February 23rd, 2006, 11:04 AM
That looks like an AC compressor for a serpinteen belt engine, and you need a compressor for a V belt engine, so no it won't work. Do you mind me asking where you could get that compressor? I am looking for a cheap one Serp belt compressor to use as an air compressor.
Old February 23rd, 2006, 11:25 AM
lactic's Avatar
lactic
AC Compressor
PM sent Mike.
Old February 23rd, 2006, 12:25 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Cant you just switch out the serp pulley for a V belt pulley?
Old February 23rd, 2006, 01:03 PM
Nope, the mounting is completely different. The Serp belt has 4 bolts that bolt down onto the belt tensioner bracket while the V belt bolts on like the alt does with 2 bolts on it's own bracket. Trust me i would have tried it myself if I thought it would have worked.
ac, compressor
AC compressor clutch squeal artm Defender Technical Discussions 9 June 14th, 2010 04:34 PM
AC compressor relay sherpamike Defender Technical Discussions 3 September 6th, 2009 02:55 PM
AC Compressor for On-board air mdmccallum Defender Technical Discussions 19 August 20th, 2008 01:02 PM
D110 300Tdi AC Compressor? Hssser Defender Technical Discussions 3 August 17th, 2005 07:47 PM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
