Abs vs non-abs swivel pins - Defender Source
Old October 13th, 2014, 07:33 PM
jafir's Avatar
jafir
Jafir Elkurd
So I'm swapping my front axle with a disco axle and I've come across a problem.
The disco axle was abs, and so the top swivel pin has an abs sensor in it. The brake lines attach differently for disco and 90, so I'm planning on using the hardware from the 90.
The problem is the abs sensors. I cannot use the 90 brake line bracket because it doesn't have a hole for the sensor. I cannot just remove the sensor because then I'll leak gear oil or grease from the hole.
Can I swap the non-abs top swivel pins?
Old October 13th, 2014, 07:45 PM
Cut the top off the sensors and right stuff them in place.
Old October 13th, 2014, 07:46 PM
jafir's Avatar
jafir
Jafir Elkurd
Thanks! Will do!
Old October 13th, 2014, 08:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
They make a pin for that but I can't remember the number. Ditto to the above about cutting off the sensor. I have also welded the hole full and then used right stuff on the inside to make sure my welds didn't leak.
Old October 13th, 2014, 08:45 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I removed the sensors and after cleaning the surfaces VERY well, I "siliconed" a US Penny(coin) in the place on the top where the senors was inserted. Been trouble free for 13 years now.
Now the real issue for me is, if I want a new swivel pin w/o the sensor hole, is one available ..... maybe one from a 110?
The pins for D90's w/o the sensors are of a smaller diameter, the swivel ball is different, etc.
Old October 14th, 2014, 06:39 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Damn Jafir I expected this thread to contain a "real" problem LOL
------ Follow up post added October 14th, 2014 06:40 PM ------
I've used vinyl plugs, but this is the best idea in this thread. Just my .02$
Old October 14th, 2014, 08:24 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I plugged the hole then filled it with right stuff. Then just install 90 brake hose bracket on top.
Legend in My Own Mind.
ABS CVs fit in non ABS car? sflash868 Defender Technical Discussions 2 July 21st, 2014 06:55 AM
Swivel Pins JPRO576 For Sale - Parts 4 August 27th, 2013 12:06 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
RR non-ABS conversion artm Defender Technical Discussions 0 April 26th, 2004 11:01 AM
NON ABS Complete brake system Way Wanted 12 November 12th, 2003 08:47 PM
