Abs - Defender Source
Old November 25th, 2011, 01:33 AM
knab's Avatar
knab
Brandon Donald
97 ST, few RRCs, P38 HSE
Abs
I assume this has been discussed before, but my searching doesn't bring up much. Have many people retrofitted ABS brakes, maybe from Discoveries, to older Defenders? I don't think it would be too tricky, but would be interested in hearing from anyone that has done it. Apologies if this has been discussed many times... I just couldn't find anything on the issue.
Old November 25th, 2011, 08:57 AM
I doubt it has been done much. The ABS on Discoverys is horribly bad so it would not be a good idea.
Old November 25th, 2011, 04:43 PM
knab's Avatar
knab
Brandon Donald
What about using the ABS system from an ROW Defender? Has anyone here done that (or any ABS installation, for that matter)?
Old November 25th, 2011, 05:37 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Why in the world would you want to add more crap like ABS to something as perfect as the brake system on a Defender?
Old November 25th, 2011, 07:32 PM
X2 why do you think you need ABS?
Old November 25th, 2011, 09:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I would question the sanity of anyone who installed D1 ABS to a Defender.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 26th, 2011, 07:12 PM
I think ECR added ABS to a defender ...
Old November 26th, 2011, 09:08 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You might be able to source a ABS from a newer defender, as mentioned above, but then you may have to mess with the ECU in that newer Defender. You would also have to change over to the ABS style hubs. I think the cost would be crazy high. But I am with some of the others in asking why?
Land Rover 110
Old November 27th, 2011, 11:03 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Wouldn't that be a function of customer demand, rather than rational design?
1970 SIIA 88, Sold
Old November 27th, 2011, 12:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
There must be some ABS system out there that doesn't fail in a way that leaves you with no brakes and no warning, like the D1 system often does.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
wtb abs control unit chirider Wanted 0 June 15th, 2005 01:19 AM
wtb abs wheel sensor chirider Wanted 0 June 13th, 2005 04:40 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
NON ABS Complete brake system Way Wanted 12 November 12th, 2003 08:47 PM
