Stupid ? but want to make sure. Took my doors apart today to clean and wax. First time. Looks like I have stainless steel studs but the nuts where completely rusted. 1st ? Looked down into door frame hole where studs go into looked a little rusty. Bottom of tube had surface rust as well. Is the tube Steel? Can I just put a stainless steel nut on the stud? Or will that promote rust. Not sure if hole is made out of steel or alum. Like I said nut was rusty maybe caused little surface rust on bottom of hole. 2nd ? If water gets into the tube how does it ever drain with a nut and washer on the bottom?
Only the skin of your door (and the door top) is aluminum, the capping, frame, and everything else is steel and likes to rust. The tube is especially bad since water collects at the bottom. I have stainless studs and quick nuts (only the AB ones - RN ones are mild steel and rust badly) and still have to take them off to drain them out periodically. Part of the problem is that putting nuts on the studs without a washer or some spacer tears up the paint at the bottom of the tubes and makes it even easier for rust to start.
Don't spend more than .002 cents on legal advice or else you won't make any profit.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
