AAACK!! help please... - Defender Source
Old July 10th, 2010, 07:54 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Bushings suck!!
Does anyone have a trick for getting the bolt through an old corroded bushing? I need to remove the trailing arms. I got them off the frame but I swear to save my life I can't get the bolts to release from the bushings...
What's the trick? I've tried a breaker bar, breaker bar with hi-lift handle extension, impact wrench, BFH, liquid wrench... what's left to try?
suggestions please?
Old July 10th, 2010, 08:35 PM
sawzall down each side. replace with new and lots of anti-sieze
Originally Posted by bharris View Post
Bushings suck!!
suggestions please?
Old July 10th, 2010, 08:39 PM
Air hammer, red wrench (which will smoke the bushing -- do not breath the fumes as they are really bad) etc.
Old July 10th, 2010, 09:13 PM
bharris's Avatar
bharris
Brad Harris
excellent... I'll start with the red wrench and go from there...
Old July 11th, 2010, 09:51 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
burn them out !
- Charles Eames
Old July 13th, 2010, 11:22 PM
bharris's Avatar
bharris
Brad Harris
For those of you keeping track at home.... just FINALLY got the last of those bloody bolts out!! and the axle housings are now completely removed from my truck!!
it took all of the following: ratchet, screwdriver, impact wrench, liquid wrench, a red wrench, air hammer, a BFH and a sawzall...
I think a little anti-seize is in order when I put it all back together don't cha' think?
ac
