a one carb manifold for the V8 engine - Defender Source
Old March 7th, 2005, 04:34 PM
DIVERPRO
Tamer Adel
Cool a one carb manifold for the V8 engine
Hi,
I have 84 V8 90 and I was wondering if it is posible to fit it with one carb like the American V8 engines, is that possible and what type of Manifold should I use? and where to get it?
Thank you.
Old March 7th, 2005, 07:35 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Edelbrock and I believe Wieand make manifolds for it with 4 barrel carbs.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 9th, 2005, 02:18 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Edelbrock part # 2198. Use the Edelbrock Carburator #1404 500cfm. You will notice a big increase in torque with a moderate increase in seat of the pant HP. I ended up using the Edelbrock Hi flow air cleaner with it. It is a pretty straight forward job. I think my next upgrade is a 3.9 cam and lifters. My engine has 172k miles on it and cruises easy at 75 but it is tired engine and will be looking at a rebuild in the next couple of years. If you have any questions let me know.
Old March 9th, 2005, 11:46 AM
pendy's Avatar
pendy
jim pendleton
89'd90
i have an old oldsmobile 215 intake hid out. It accepts the Quadrajet carb. Make offer.
JP
legend in my own mind
engine, v8
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
need pic of v8 engine mounts on frame btate Defender Technical Discussions 2 June 19th, 2009 09:18 AM
Take out V8 engine and trans--complete evilfij Wanted 9 June 17th, 2004 06:00 PM
» Defender Registry
Meh-Teh
thewap
MOD110
Mod110
Add your Defender
